| From 2.1 to 2.3 [message #899740] |
Thu, 02 August 2012 03:35  |
Goran M. Messages: 10 Registered: April 2012 |
Junior Member |
I recently changed to v2.3 and now I'm getting the following error when executing the editor:
You are using a deprecated implementation of IjvmModelInferrer. Please change the type of the acceptor in your 'infer' method. It should be 'org.eclipse.xtext.xbase.jvmmodel.IJvmDeclaredTypeAcceptor'.This backward compatibility mode will be removed in the next release (2.3 June 2012).
My ModelInferrer is the generated one and I did not modify it at all. So I get
the "wrong" code generated.
What can I do to get rid of this error/warning?
Goran
FUDForum. Page generated in 0.01771 seconds
