Home » Eclipse Projects » WindowBuilder » Generic Panel/Dialog with Actions will not render GUI
Generic Panel/Dialog with Actions will not render GUI [message #899699] Wed, 01 August 2012 18:55 Go to next message
Dave Radtke is currently offline Dave Radtke
I have a generic class that extends JPanel. As soon as I introduce an Action the class will no longer generate the UI. I get a null pointer exception.
If I make the class non-generic, or I don't create an instance of the Action in the constructor then it will generate the UI successfully.
I have been able to reproduce this on multiple classes (JPanel and JDialog), attached in a report from a simple example that does not need to be generic, but is a simple example that removes other dependencies and possible other causes
public class OKCancelDialog<T> extends JDialog {
	protected JPanel buttonPanel;
	protected JButton btnOk;
	protected JFrame frame;
	public OKCancelDialog(JFrame frame,boolean modal) {
		super(frame,modal);
		buttonPanel = new JPanel();
		FlowLayout flowLayout = (FlowLayout) buttonPanel.getLayout();
		flowLayout.setAlignment(FlowLayout.RIGHT);
		getContentPane().add(buttonPanel, BorderLayout.SOUTH);
		btnOk = new JButton("OK");
		btnOk.setAction(new OKAction());
		buttonPanel.add(btnOk);
	private class OKAction extends AbstractAction {
		public OKAction() {
			putValue(NAME, "ok");
		public void actionPerformed(ActionEvent e) {
			setVisible(false);
	at org.eclipse.wb.internal.swing.model.bean.ActionInfo.refreshIconImage(ActionInfo.java:118)
	at org.eclipse.wb.internal.swing.model.bean.ActionInfo.access$1(ActionInfo.java:115)
	at org.eclipse.wb.internal.swing.model.bean.ActionInfo$3.refreshed(ActionInfo.java:83)
	at sun.reflect.GeneratedMethodAccessor111.invoke(Unknown Source)
Re: Generic Panel/Dialog with Actions will not render GUI [message #899704 is a reply to message #899699] Wed, 01 August 2012 22:11 Go to previous messageGo to next message
Konstantin Scheglov is currently offline Konstantin Scheglov
Fixed in trunk.
Konstantin Scheglov,
Google, Inc.
Re: Generic Panel/Dialog with Actions will not render GUI [message #899706 is a reply to message #899704] Wed, 01 August 2012 23:26 Go to previous message
Excellent, thanks! How often does the update site get updated?
http ://dl.google.com/eclipse/inst/d2wbpro/latest/3.6
Previous Topic:add child in parent constructor
Next Topic:ClassLoader
Current Time: Tue Jun 18 01:13:48 EDT 2013
Powered by FUDForum. Page generated in 0.01744 seconds
