| Dependency in grammars [message #899703] |
Wed, 01 August 2012 21:31  |
daniel Ramos Messages: 21 Registered: July 2012 |
Junior Member |
I'm working with two grammars, and they are not in the same classpath. So I called the .ecore in one of the languages so I can refer some rules from the other grammar. Also as I read in the xtext documentation, since i called via Resource URIs, I added in the workflow the rule referencedGenModels.
The problem is that the second grammar is not running. The error is the next:
at com.google.inject.InjectorBuilder$1.call(InjectorBuilder.java:200)
at com.google.inject.InjectorBuilder$1.call(InjectorBuilder.java:194)
at com.google.inject.InjectorImpl.callInContext(InjectorImpl.java:804)
at com.google.inject.InjectorBuilder.loadEagerSingletons(InjectorBuilder.java:194)
at com.google.inject.InjectorBuilder.injectDynamically(InjectorBuilder.java:176)
... 66 more
Caused by: java.lang.ClassNotFoundException: org.xtext.example.primero.myDsl.MyDslPackage
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
... 87 more
Root exception:
com.google.inject.CreationException: Guice creation errors:
1) Error injecting method, java.lang.NoClassDefFoundError: org/xtext/example/primero/myDsl/MyDslPackage
at org.eclipse.xtext.validation.AbstractInjectableValidator.register(AbstractInjectableValidator.java:40)
while locating org.xtext.example.secondLanguage.validation.LeDslJavaValidator
1 error
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:354)
at com.google.inject.InjectorBuilder.injectDynamically(InjectorBuilder.java:179)
at com.google.inject.InjectorBuilder.build(InjectorBuilder.java:113)
at com.google.inject.Guice.createInjector(Guice.java:92)
at com.google.inject.Guice.createInjector(Guice.java:69)
at com.google.inject.Guice.createInjector(Guice.java:59)
at org.xtext.example.secondLanguage.ui.internal.LeDslActivator.registerInjectorFor(LeDslActivator.java:47)
at org.xtext.example.secondLanguage.ui.internal.LeDslActivator.start(LeDslActivator.java:38)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:299)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:268)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:463)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.get(ResourceServiceProviderDescriptor.java:40)
at org.eclipse.xtext.internal.ResourceServiceProviderDescriptor.get(ResourceServiceProviderDescriptor.java:1)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl$InternalData.getServiceProvider(ResourceServiceProviderRegistryImpl.java:40)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:75)
at org.eclipse.xtext.resource.impl.ResourceServiceProviderRegistryImpl.getResourceServiceProvider(ResourceServiceProviderRegistryImpl.java:91)
at org.eclipse.xtext.ui.resource.UriValidator.isValid(UriValidator.java:27)
at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.isValidUri(Storage2UriMapperImpl.java:99)
at org.eclipse.xtext.ui.resource.Storage2UriMapperImpl.getUri(Storage2UriMapperImpl.java:83)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.getUri(ToBeBuiltComputer.java:136)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateStorage(ToBeBuiltComputer.java:114)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer$2.visit(ToBeBuiltComputer.java:103)
at org.eclipse.core.internal.resources.Resource$2.visit(Resource.java:106)
at org.eclipse.core.internal.resources.Resource$1.visitElement(Resource.java:65)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:82)
at org.eclipse.core.internal.watson.ElementTreeIterator.doIteration(ElementTreeIterator.java:86)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate(ElementTreeIterator.java:127)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:75)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:104)
at org.eclipse.core.internal.resources.Resource.accept(Resource.java:88)
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateProject(ToBeBuiltComputer.java:98)
at org.eclipse.xtext.builder.impl.javasupport.JdtToBeBuiltComputer.updateProject(JdtToBeBuiltComputer.java:78)
at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:181)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:85)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.NoClassDefFoundError: org/xtext/example/primero/myDsl/MyDslPackage
at org.xtext.example.secondLanguage.leDsl.impl.LeDslPackageImpl.init(LeDslPackageImpl.java:102)
at org.xtext.example.secondLanguage.leDsl.LeDslPackage.<clinit>(LeDslPackage.java:61)
at org.xtext.example.secondLanguage.validation.AbstractLeDslJavaValidator.getEPackages(AbstractLeDslJavaValidator.java:16)
at $org.eclipse.xtext.validation.AbstractInjectableValidator$$FastClassByGuice$$2999770a.invoke(<generated>)
at com.google.inject.internal.cglib.reflect.FastMethod.invoke(FastMethod.java:53)
at com.google.inject.SingleMethodInjector$1.invoke(SingleMethodInjector.java:59)
at com.google.inject.SingleMethodInjector.inject(SingleMethodInjector.java:91)
at com.google.inject.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:99)
at com.google.inject.ConstructorInjector.construct(ConstructorInjector.java:94)
at com.google.inject.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:111)
at com.google.inject.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:45)
at com.google.inject.InjectorImpl.callInContext(InjectorImpl.java:811)
at com.google.inject.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:42)
at com.google.inject.Scopes$1$1.get(Scopes.java:54)
at com.google.inject.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:48)
... 66 more
... 87 more
322 [Worker-2] ERROR org.eclipse.xtext.internal.ResourceServiceProviderDescriptor - Plug-in segundoLenguaje.ui was unable to load class org.xtext.example.secondLanguage.ui.LeDslExecutableExtensionFactory.
org.eclipse.core.runtime.CoreException: Plug-in segundoLenguaje.ui was unable to load class org.xtext.example.secondLanguage.ui.LeDslExecutableExtensionFactory.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle segundoLenguaje.ui (587).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
... 39 more
Caused by: org.osgi.framework.BundleException: Exception in org.xtext.example.secondLanguage.ui.internal.LeDslActivator.start() of bundle segundoLenguaje.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
... 51 more
Caused by: com.google.inject.CreationException: Guice creation errors:
1 error
... 57 more
... 66 more
... 87 more
!ENTRY org.apache.log4j 4 0 2012-07-31 16:31:50.933
!MESSAGE org.eclipse.xtext.internal.ResourceServiceProviderDescriptor - Plug-in segundoLenguaje.ui was unable to load class org.xtext.example.secondLanguage.ui.LeDslExecutableExtensionFactory.
!STACK 1
... 39 more
... 51 more
1 error
... 57 more
... 66 more
... 87 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-07-31 16:31:50.935
!MESSAGE Plug-in segundoLenguaje.ui was unable to load class org.xtext.example.secondLanguage.ui.LeDslExecutableExtensionFactory.
!STACK 0
... 51 more
1 error
... 57 more
... 66 more
... 87 more
[Fatal Error] :1:1: Premature end of file.
2889 [Worker-2] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Plugin segundoLenguaje.ui, extension org.eclipse.xtext.builder.participant
!ENTRY org.apache.log4j 4 0 2012-07-31 16:31:53.511
!MESSAGE org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Plugin segundoLenguaje.ui, extension org.eclipse.xtext.builder.participant
2974 [Worker-2] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Plug-in segundoLenguaje.ui was unable to load class org.xtext.example.secondLanguage.ui.LeDslExecutableExtensionFactory.
!ENTRY org.apache.log4j 4 0 2012-07-31 16:31:53.583
!MESSAGE org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Plug-in segundoLenguaje.ui was unable to load class org.xtext.example.secondLanguage.ui.LeDslExecutableExtensionFactory.
3030 [Worker-2] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Plugin segundoLenguaje.ui, extension org.eclipse.xtext.builder.participant
!ENTRY org.apache.log4j 4 0 2012-07-31 16:31:53.638
3032 [Worker-2] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Error processing extension: org.eclipse.core.internal.registry.ConfigurationElementHandle@3ee9
!ENTRY org.apache.log4j 4 0 2012-07-31 16:31:53.640
!MESSAGE org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Error processing extension: org.eclipse.core.internal.registry.ConfigurationElementHandle@3ee9
3060 [Worker-2] ERROR org.eclipse.xtext.internal.ResourceServiceProviderDescriptor - Plug-in segundoLenguaje.ui was unable to load class org.xtext.example.secondLanguage.ui.LeDslExecutableExtensionFactory.
at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.updateProjectNewResourcesOnly(ToBeBuiltComputer.java:73)
at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:180)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:321)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:396)
at org.eclipse.core.internal.resources.Project$1.run(Project.java:618)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:597)
at org.eclipse.core.internal.resources.Project.build(Project.java:124)
at org.eclipse.xtext.builder.impl.BuildScheduler$BuildJob.run(BuildScheduler.java:101)
... 1 more
... 51 more
1 error
... 57 more
... 66 more
... 87 more
!ENTRY org.apache.log4j 4 0 2012-07-31 16:31:53.670
!STACK 1
| Re: Dependency in grammars [message #899897 is a reply to message #899718] |
Thu, 02 August 2012 14:05   |
Junior Member |
Thanks for the answer.
I already made a project of xtext with two grammars in the same classpath. I defined the grammars and one of those has some dependency with the other (It has cross-reference to the rules of the other grammar). I modified the workflow to add the new grammar and generate his/her respective java class. But when I run the eclipse aplication and try to generate a file with the extension for the second grammar i got the next error:
1 [Worker-3] ERROR org.xtext.example.secondLanguage.ui.internal.LeDslActivator - Guice creation errors:
1) Error injecting method, java.lang.Error: Unresolved compilation problem:
MyDslPackage cannot be resolved
1 error
1 error
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader.readElement(RegistryBuilderParticipant.java:102)
at org.eclipse.emf.ecore.plugin.RegistryReader.internalReadElement(RegistryReader.java:123)
at org.eclipse.emf.ecore.plugin.RegistryReader.readRegistry(RegistryReader.java:93)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.initParticipants(RegistryBuilderParticipant.java:80)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.getParticipants(RegistryBuilderParticipant.java:67)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:52)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:160)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:141)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:91)
Caused by: java.lang.Error: Unresolved compilation problem:
... 51 more
!SESSION 2012-08-02 13:03:36.803 -----------------------------------------------
eclipse.buildId=M20120208-0800
java.version=1.6.0_21
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=es_CO
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data C:\trabajo ejemplo/../runtime-EclipseApplication -dev file:C:/trabajo ejemplo/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.apache.log4j 4 0 2012-08-02 13:04:02.584
!MESSAGE org.xtext.example.secondLanguage.ui.internal.LeDslActivator - Guice creation errors:
1 error
!STACK 0
1 error
... 51 more
!ENTRY org.eclipse.osgi 4 0 2012-08-02 13:04:02.615
!MESSAGE An error occurred while automatically activating bundle segundoLenguaje.ui (587).
!STACK 0
1 error
... 42 more
... 51 more
Root exception:
1 error
... 51 more
68 [Worker-3] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Plugin segundoLenguaje.ui, extension org.eclipse.xtext.builder.participant
!ENTRY org.apache.log4j 4 0 2012-08-02 13:04:02.648
73 [Worker-3] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Plug-in segundoLenguaje.ui was unable to load class org.xtext.example.secondLanguage.ui.LeDslExecutableExtensionFactory.
!ENTRY org.apache.log4j 4 0 2012-08-02 13:04:02.834
259 [Worker-3] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Plugin segundoLenguaje.ui, extension org.eclipse.xtext.builder.participant
!ENTRY org.apache.log4j 4 0 2012-08-02 13:04:02.836
261 [Worker-3] ERROR org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$BuilderParticipantReader - Error processing extension: org.eclipse.core.internal.registry.ConfigurationElementHandle@3ee9
!ENTRY org.apache.log4j 4 0 2012-08-02 13:04:02.837
| Re: Dependency in grammars [message #899901 is a reply to message #899897] |
Thu, 02 August 2012 14:11  |
Christian Dietrich Messages: 4387 Registered: July 2009 |
Hi Make it easy
Create two Xtext projects.
Add the first as plugin dependency to the second.
Import the ecore of the first to the second grammar.
Fix registergeneratedepackage and registergenmodel (or something like
that) in the stand alone setup of the second workflow
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
FUDForum. Page generated in 0.02638 seconds
