Home » Eclipse Projects » IMP » Create a p2 repositories for IMP packages(Need to create p2 repositories for the IMP as I am using maven tyco for building my eclipse plugins)
Create a p2 repositories for IMP packages [message #799836] Thu, 16 February 2012 06:18 Go to next message
Dyutimoy Sarkar is currently offline Dyutimoy Sarkar
I am using maven3 and tyco plugins to build eclipse plugins.
Our plugins have dependency with bundles available in IMP update site.
Because maven tyco resolves from p2 repository and IMP project does not have p2 metadata, maven is not able to resolve the dependencies.
I tried the following steps
./eclipse.exe -debug -consolelog -nosplash -verbose -application org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher -metadataRepository S:\p2repo" -artifactRepository S:\repo -source D:\build_material\new -compress -append -publishArtifacts
I got the following exception.
Any help will be greatly appreciated. If some one can point me to p2 repository for IMP Bundles will solve my problem Smile
!ENTRY org.eclipse.equinox.app 4 0 2012-02-16 02:56:59.123
!MESSAGE Repository not modifiable: S:%5Crepo
!STACK 0
java.lang.UnsupportedOperationException: Repository not modifiable: S:%5CViews%5Crepo
at org.eclipse.equinox.internal.provisional.spi.p2.repository.AbstractRepository.assertModifiable(AbstractRepository.java:54)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.save(SimpleArtifactRepository.java:881)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.save(SimpleArtifactRepository.java:877)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.<init>(SimpleArtifactRepository.java:298)
at org.eclipse.equinox.internal.provisional.spi.p2.artifact.repository.SimpleArtifactRepositoryFactory.create(SimpleArtifactRepositoryFactory.java:123)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.factoryCreate(ArtifactRepositoryManager.java:55)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.doCreateRepository(AbstractRepositoryManager.java:272)
at org.eclipse.equinox.internal.p2.artifact.repository.ArtifactRepositoryManager.createRepository(ArtifactRepositoryManager.java:48)
at org.eclipse.equinox.p2.publisher.Publisher.createArtifactRepository(Publisher.java:119)
at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.initializeRepositories(AbstractPublisherApplication.java:98)
at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.initialize(AbstractPublisherApplication.java:89)
at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.run(AbstractPublisherApplication.java:284)
at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.run(AbstractPublisherApplication.java:261)
at org.eclipse.equinox.p2.publisher.AbstractPublisherApplication.start(AbstractPublisherApplication.java:322)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
at java.lang.Thread.run(Unknown Source)
Re: Create a p2 repositories for IMP packages [message #899524 is a reply to message #799836] Wed, 01 August 2012 05:43 Go to previous message
Wolfgang Geck is currently offline Wolfgang Geck
P2 is so fragile! Try this modification but leave the -source argument to avoid another problem:)
./eclipse.exe -debug -consolelog -nosplash -verbose -application org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher -metadataRepository file:\\S:\p2repo" -artifactRepository file:\\S:\repo -source D:\build_material\new -compress -append -publishArtifacts
Previous Topic:As is Project?
Current Time: Mon May 27 23:07:17 EDT 2013
Powered by FUDForum. Page generated in 0.01669 seconds
