| Eclipse 4.2 crashes on Ubuntu 10.04 64bit [message #899509] |
Wed, 01 August 2012 04:50  |
Sihan goi Messages: 4 Registered: March 2012 |
Junior Member |
I'm trying to run Eclipse 4.2 on my Ubuntu 10.04 LTS 64bit PC.
I have both 32bit and 64bit versions, but neither work.
I've installed jdk6.
When I run the 32bit, this error message pops up:
JVM terminated. Exit code=13
/usr/bin/java
-Xms40m
-Xmx512m
-XX:MaxPermSize=256m
-jar /home/goister/android/eclipse//plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
-os linux
-ws gtk
-arch x86
-showsplash /home/goister/android/eclipse//plugins/org.eclipse.platform_4.2.0.v201206081400/splash.bmp
-launcher /home/goister/android/eclipse/eclipse
-name Eclipse
--launcher.library /home/goister/android/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_1.1.200.v20120522-1813/eclipse_1502.so
-startup /home/goister/android/eclipse//plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.overrideVmargs
-exitdata 408015
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx512m
In my terminal, I get the following output
/usr/lib/gio/modules/libgvfsdbus.so: wrong ELF class: ELFCLASS64
Failed to load module: /usr/lib/gio/modules/libgvfsdbus.so
/usr/lib/gio/modules/libgiogconf.so: wrong ELF class: ELFCLASS64
Failed to load module: /usr/lib/gio/modules/libgiogconf.so
/usr/lib/gio/modules/libgioremote-volume-monitor.so: wrong ELF class: ELFCLASS64
Failed to load module: /usr/lib/gio/modules/libgioremote-volume-monitor.so
When I run the 64bit, this error message pops up:
/usr/bin/java
-Xms40m
-Xmx512m
-os linux
-ws gtk
-arch x86
-name Eclipse
-exitdata 418015
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx512m
gogo: CommandNotFoundException: Command not found: gosh
org.apache.felix.gogo.runtime.CommandNotFoundException: Command not found: gosh
at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:466)
at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:395)
at org.apache.felix.gogo.runtime.Pipe.run(Pipe.java:108)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:183)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:120)
at org.apache.felix.gogo.runtime.CommandSessionImpl.execute(CommandSessionImpl.java:89)
at org.apache.felix.gogo.shell.Activator.run(Activator.java:75)
at java.lang.Thread.run(Thread.java:619)
Does anyone know what's wrong?
Thanks.
| Re: Eclipse 4.2 crashes on Ubuntu 10.04 64bit [message #899528 is a reply to message #899521] |
Wed, 01 August 2012 05:51  |
Thomas Schindl Messages: 4462 Registered: July 2009 |
I'm sorry to say but this is not true:
This line indicates that you run, the 32bit version:
----8<----
----8<----
it's the same in both of your logs. So you are definately not starting a
64bit eclipse.
Tom
Am 01.08.12 11:30, schrieb Sihan goi:
> Like I said, I tried both 32bit and 64bit Eclipse. The error messages
> for the 64bit version is in the later half of my original post.
FUDForum. Page generated in 0.02463 seconds
