Home » Language IDEs » Java Development Tools (JDT) » How to provide default "Type filter"
How to provide default "Type filter" [message #899072] Mon, 30 July 2012 09:32 Go to next message
Lars Vogel is currently offline Lars Vogel
Under Java -> Appearance -> Type Filters I can enter filters for types I don't want to use. As I never use java.awt and javax.swing I would like to create some default settings for example via plugin_customization.ini.
Is this possible? I used grep to search through the .metadata/.plugins directory but I found only binary files.
Re: How to provide default "Type filter" [message #899289 is a reply to message #899072] Tue, 31 July 2012 07:09 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
e.g.
org.eclipse.jdt.ui/org.eclipse.jdt.ui.typefilter.enabled=javax.*;
Hint to find such keys:
1. start a new workspace
2. change the preference
3. export all preferences
4. search the key in the exported file
Note that you need to remove the scope (e.g. /instance/) before copying
it into the plugin_customization.ini file.
Dani
Re: How to provide default "Type filter" [message #899315 is a reply to message #899289] Tue, 31 July 2012 09:03 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
Can typfilters also get applied to Projects, or only generally on the
whole workspace?
Tom
Am 31.07.12 13:09, schrieb Daniel Megert:
> e.g.
> Dani
Re: How to provide default "Type filter" [message #899370 is a reply to message #899289] Tue, 31 July 2012 11:12 Go to previous message
Thanks Dani, works fine for me.
Previous Topic:Adding a Nature/Builder automatically to a project
Next Topic:Using ADK with Relative Layout on Eclipse
Current Time: Thu May 23 19:53:28 EDT 2013
Powered by FUDForum. Page generated in 0.01677 seconds
