Home » Eclipse Projects » scout » File upload to server
File upload to server [message #897906] Wed, 25 July 2012 08:09 Go to next message
Stefan Mutschler is currently offline Stefan Mutschler
Hi!
How can I upload a file from the client to the server? RemoteFileService contains a method putRemoteFile() which sounds like a possible candidate but it is disabled for remote access (annotated with @RemoteServiceAccessDenied). I'd like to store client contracts in a server directory.
Stefan
Re: File upload to server [message #898380 is a reply to message #897906] Thu, 26 July 2012 05:58 Go to previous messageGo to next message
Bertin Kiekebosch is currently offline Bertin Kiekebosch
if you want to test if the putRemoteFile() works for you, you could create your own fileservice, copy the code into it and test it.
Don't forget to register your service
regards Bertin
Re: File upload to server [message #899292 is a reply to message #898380] Tue, 31 July 2012 07:27 Go to previous messageGo to next message
Claudio Guglielmo is currently offline Claudio Guglielmo
Member
Hi there
The annotation is present due to security reasons. Calling this method is possible but only from the server. So you have to create a custom service which delegates the file upload to the RemoteFileService.
This gives you the possibility to allow or deny a file upload.
Btw: If you would like to store your files in a database you do not necessarly have to use the remote file service. Instead, you could create a byte[] and send it to the server. Have a look at the IOUtility for helper methods.
Claudio
Re: File upload to server [message #899338 is a reply to message #899292] Tue, 31 July 2012 09:50 Go to previous message
Ah, I see... makes sense. I'll create a custom service.
Thank you both...
Previous Topic:Wrong behavior of SmartField Ubuntu 12.04 /SWT
Next Topic:Multi-Module Applications
Current Time: Thu May 23 09:38:20 EDT 2013
Powered by FUDForum. Page generated in 0.01965 seconds
