Home » Newcomers » Newcomers » Syntax Coloring in JSP Scriptlets.(How to get syntax coloring in JSP scriptlets.)
Syntax Coloring in JSP Scriptlets. [message #898810] Fri, 27 July 2012 13:52 Go to next message
Steven Edmunds is currently offline Steven Edmunds
When I open a JSP page in the Eclipse JSP editor the Java code in the scriptlet elements are not highlighted except for the Java keywords (green), Strings (light green), and the comments (italicized). How do I change this highlighting, preferrably to the same Java syntax coloring.
I'm using Eclipse Indigo Java EE bundle and a Java 1.6 jdk.
Re: Syntax Coloring in JSP Scriptlets. [message #899178 is a reply to message #898810] Mon, 30 July 2012 17:18 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
The styling should already be identical to what you find in the Java
Editor. Is it not? Are you sure its the JSP Editor from eclipse.org
that you're using?
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:run configs - path & file name arguments
Next Topic:Trouble exporting .jar file
Current Time: Thu May 23 18:49:39 EDT 2013
Powered by FUDForum. Page generated in 0.08471 seconds
