Home » Eclipse Projects » Eclipse 4 » Where are the code snippets?
Where are the code snippets? [message #898756] Fri, 27 July 2012 09:02 Go to next message
c.sileo is currently offline c.sileo
I've been working until now with eclipse indigo, where I used the code snippet view. It was located in the "general" section when opening a new view.
Now, in Juno, it's not there anymore. I found a view called "templates", and though having the same icon it doesn't work at all.
Is it a plugin I can install? If so, where can I find it?
Re: Where are the code snippets? [message #898851 is a reply to message #898756] Sat, 28 July 2012 00:09 Go to previous messageGo to next message
Enrico R. is currently offline Enrico R.
Member
The snippets view is available after you have installed the "Eclipse Java Web Developer Tools".
I must apologize, I had to correct my previous statement.
best regards
Rico
[Updated on: Sat, 28 July 2012 00:22]
Report message to a moderator
Re: Where are the code snippets? [message #899035 is a reply to message #898851] Mon, 30 July 2012 05:45 Go to previous messageGo to next message
Thank you very much, that's it!
I installed those web developer tools, and all my old snippets are there again. Meaning I can work now with the latest eclipse version.
Thanks a lot!
Re: Where are the code snippets? [message #899113 is a reply to message #898851] Mon, 30 July 2012 11:19 Go to previous messageGo to next message
Joseph Carroll is currently offline Joseph Carroll
The 'Snippets' view should be available with every distribution.
Window -> Show View -> Other -> General -> Snippets
The default location for the view will be in the lower part-stack with the console and related views.
JD
Re: Where are the code snippets? [message #1001852 is a reply to message #899113] Thu, 17 January 2013 07:56 Go to previous messageGo to next message
Valentin Despa is currently offline Valentin Despa
@Enrico R., thank you very much, worked like a charm.
@Joseph Carroll It seems that the 'Snippets' are not inside the Classic distribution I was using.
Re: Where are the code snippets? [message #1001855 is a reply to message #899113] Thu, 17 January 2013 07:58 Go to previous message
Previous Topic:Unit tests on a e4 Application.
Next Topic:Putting a PerspectiveStack on a Part
Current Time: Thu May 23 05:02:24 EDT 2013
Powered by FUDForum. Page generated in 0.02839 seconds
