| From RWT to full RAP on Virgo [message #898953] |
Sun, 29 July 2012 05:51 |
I'm a RAP newbie and I have some questions about RAP:
I followed the RAP on Virgo tutorial (I used Viro 3.5 instead of the 3.0.3 version and it works perfectly).
* I wanted to know if I can integrate JFaces and rap.ui rap.forms... as easily as it was for rwt?
* Then, is sever push (rap way) is supported by native rwt (if I can't integrate the other frameworks).
* Finally, how do I support the eclipse 'extensions' (that are usually located in plugins.xml eclipse files) in a plain OSGI environnement (via OSGI services, or including some equinox libs to support plugins.xml files)?
I wanted to thank you for this promising frameworks.
My best, Charlie
FUDForum. Page generated in 0.01657 seconds
