Home » Modeling » TMF (Xtext) » handling both latin-1 and utf-8 files
handling both latin-1 and utf-8 files [message #898707] Fri, 27 July 2012 05:33 Go to next message
Vlad Dumitrescu is currently offline Vlad Dumitrescu
Hi!
My language files are encoded as Latin-1, but since the compiler's parser accepts anything inside comments and strings, many people in china and Russia and elsewhere use utf-8 in those places.
I did some quick tests and it looks like Xtext can handle those. Are there any hidden traps here?
best regards,
Vlad
Re: handling both latin-1 and utf-8 files [message #899013 is a reply to message #898707] Mon, 30 July 2012 03:37 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian Zarnekow
Hi Vlad,
Xtext can handle all encodings quite well (see IEncodingProvider). Of
course, you cannot mix encodings in the same file.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 27.07.12 11:33, schrieb Vlad Dumitrescu:
> Hi!
> best regards,
> Vlad
Re: handling both latin-1 and utf-8 files [message #899017 is a reply to message #899013] Mon, 30 July 2012 03:49 Go to previous message
Thank you, Sebastian.
What I meant was - with an infrastructure generated for a Latin-1 encoding, does it work to handle utf-8 files too, given the restriction that non-ascii characters are only found in comments and strings?
regards,
Vlad
Previous Topic:Updating Xtext 2.2.1 to 2.3.0
Next Topic:import an Xtext grammar
Current Time: Fri May 24 00:26:44 EDT 2013
Powered by FUDForum. Page generated in 0.01694 seconds
