Home » Eclipse Projects » Jubula » "Renderer not Supported" Error
"Renderer not Supported" Error [message #897776] Wed, 25 July 2012 04:49 Go to next message
Moritz D. is currently offline Moritz D.
I get an "Renderer not Supported" Action Error.
I want to test a java application and have a table with a default cell renderer. I got a checkbox which is wrapped in a JPanel because I want to set a custom background color. Without the JPanel the checkbox overwrites the background always in white. I'm using the "Nimbus" Look & Feel.
Any other ideas how I could check the value of the checkbox without getting this error?
Or do you know a better way how to implement the checkbox with a custom background color in the table?
Thanks for your help!!!
Re: "Renderer not Supported" Error [message #898650 is a reply to message #897776] Fri, 27 July 2012 01:26 Go to previous message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
Is it a Swing application? If so, you can add support for your own renderers:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=351926
Not sure how to do this if it is for RCP...
Alex
Previous Topic:Setup Java applet application
Next Topic:Unable to Execute SimpleAdder Project
Current Time: Fri May 24 03:56:49 EDT 2013
Powered by FUDForum. Page generated in 0.01762 seconds
