Home » Modeling » OCL » Referencing to OCL constraint
Referencing to OCL constraint [message #898426] Thu, 26 July 2012 07:27 Go to next message
Wouter Schaekers is currently offline Wouter Schaekers
Hi.
I was wondering whether it is possible to reference to an OCL constraint in a derivation property/attribute. To give a simple example:
Invariant Bigger:
self.num > 5;
Now I want to use 'Bigger' in a derivation. Eg:
derivation: if Bigger then ... else ... endif
Is this possible or do I have to do double work?
Thanks.
Re: Referencing to OCL constraint [message #898463 is a reply to message #898426] Thu, 26 July 2012 08:21 Go to previous messageGo to next message
HI
Yes/No.
Ecore supports two kinds of invariant, one callable, one not.
Using the OCLinEcore editor you can annotate an invariant as 'callable'.
But an invariant is always/true/false on a valid/invalid model, so it
makes no sense to use it in an if.
If you want a re-useable expression, warp it as an operation or property.
property isBigger : Boolean {transient, volatile} { derivation:
self.num > 5; }
invariant Bigger: isBigger;
On 26/07/2012 12:27, Wouter Schaekers wrote:
> Hi.
> Invariant Bigger:
> self.num > 5;
> Thanks.
Re: Referencing to OCL constraint [message #898474 is a reply to message #898463] Thu, 26 July 2012 08:52 Go to previous message
Ed Willink wrote on Thu, 26 July 2012 08:21
That sounds very logical. Smile
self.num > 5; }
This works. Thanks.
[Updated on: Thu, 26 July 2012 08:52]
Report message to a moderator
Previous Topic:Package as Ocl Context
Next Topic:Concat collection
Current Time: Sat May 25 09:03:06 EDT 2013
Powered by FUDForum. Page generated in 0.01516 seconds
