Home » Eclipse Projects » EclipseLink » MOXy + Tomcat6 + Maven(Howto use moxy with maven and tomcat6)
icon5.gif  MOXy + Tomcat6 + Maven [message #898370] Thu, 26 July 2012 05:34 Go to next message
jeremie drouet is currently offline jeremie drouet
I'm trying to make a web application which will handle Web Services. To do this I've 3 project on eclipse :
- Core : project with classes and interfaces
- Client : project which depends of the Core (Maven trick)
- Server : project which depends of the core too
I'm trying to set up Moxy in order to remove a cyclic graph error.
This problem comes from 2 classes :
(/src/main/java/core/object/BasicObject)
(/src/main/java/core/object/BasicRefObject)
/src/main/java/core/application/Voltage
/src/main/java/core/application/VoltageValue
package core.object.application;
import java.util.Date;
import java.util.List;
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.GeneratedValue;
import javax.persistence.GenerationType;
import javax.persistence.Id;
import javax.persistence.JoinColumn;
import javax.persistence.ManyToOne;
import javax.persistence.OneToMany;
import javax.persistence.Table;
import javax.xml.bind.annotation.XmlRootElement;
import org.eclipse.persistence.oxm.annotations.XmlInverseReference;
import org.hibernate.annotations.LazyCollection;
import org.hibernate.annotations.LazyCollectionOption;
import core.object.BasicRefObject;
import core.object.system.User;
@Entity
@Table(name = "Voltage")
@XmlRootElement()
public class Voltage extends BasicRefObject {
	private static final long serialVersionUID = -7590340638662303349L;
	@Id
	@GeneratedValue(strategy = GenerationType.AUTO)
	@Column(name = "id", nullable = false)
	private long id;
	@ManyToOne
	@JoinColumn(name = "creator", nullable = false)
	private User creator;
	@Column(name = "creationDate", nullable = false)
	private Date creationDate;
	@Column(name = "reference", nullable = false, unique = true)
	private String reference;
	@Column(name = "description", nullable = false)
	private String description;
	@LazyCollection(LazyCollectionOption.FALSE)
	@OneToMany(mappedBy = "voltage")
	@XmlInverseReference(mappedBy = "voltage")
	private List<VoltageValue> voltageValueList;
	 * @return the id
	public long getId() {
		return id;
	 * @param id the id to set
	public void setId(long id) {
		this.id = id;
	 * @return the creator
	public User getCreator() {
		return creator;
	 * @param creator the creator to set
	public void setCreator(User creator) {
		this.creator = creator;
	 * @return the creationDate
	public Date getCreationDate() {
		return creationDate;
	 * @param creationDate the creationDate to set
	public void setCreationDate(Date creationDate) {
		this.creationDate = creationDate;
	 * @return the reference
	public String getReference() {
		return reference;
	 * @param reference the reference to set
	public void setReference(String reference) {
		this.reference = reference;
	 * @return the description
	public String getDescription() {
		return description;
	 * @param description the description to set
	public void setDescription(String description) {
		this.description = description;
	 * @return the voltageValueList
	public List<VoltageValue> getVoltageValueList() {
		return voltageValueList;
	 * @param voltageValueList the voltageValueList to set
	public void setVoltageValueList(List<VoltageValue> voltageValueList) {
		this.voltageValueList = voltageValueList;
import core.object.BasicObject;
@Entity
@Table(name = "VoltageValue")
@XmlRootElement()
public class VoltageValue extends BasicObject {
	private static final long serialVersionUID = 5563489030736775097L;
	@Id
	private long id;
	@ManyToOne
	@ManyToOne
	@JoinColumn(name = "voltage", nullable = false)
	private Voltage voltage;
	@ManyToOne
	@JoinColumn(name = "torque", nullable = false)
	private Torque torque;
	@ManyToOne
	@JoinColumn(name = "typeOfVoltageValue", nullable = false)
	private TypeOfVoltageValue typeOfVoltageValue;
	@Column(name = "frequency", nullable = false)
	private double frequency;
	@Column(name = "value", nullable = false)
	private double value;
	 * @return the id
		return id;
		this.id = id;
		return creator;
	public Voltage getVoltage() {
		return voltage;
	 * @param voltage the voltage to set
	public void setVoltage(Voltage voltage) {
		this.voltage = voltage;
	 * @return the torque
	public Torque getTorque() {
		return torque;
	 * @param torque the torque to set
	public void setTorque(Torque torque) {
		this.torque = torque;
	 * @return the typeOfVoltageValue
	public TypeOfVoltageValue getTypeOfVoltageValue() {
		return typeOfVoltageValue;
	 * @param typeOfVoltageValue the typeOfVoltageValue to set
	public void setTypeOfVoltageValue(TypeOfVoltageValue typeOfVoltageValue) {
		this.typeOfVoltageValue = typeOfVoltageValue;
	 * @return the frequency
	public double getFrequency() {
		return frequency;
	 * @param frequency the frequency to set
	public void setFrequency(double frequency) {
		this.frequency = frequency;
	 * @return the value
	public double getValue() {
		return value;
	 * @param value the value to set
	public void setValue(double value) {
		this.value = value;
And set up Moxy, I put a jaxb.properties in /src/main/resources and I put this in the pom.xml of the Core
<plugin>
				<artifactId>maven-resources-plugin</artifactId>
				<version>2.5</version>
				<executions>
					<execution>
						<id>copy-resources</id>
						<phase>validate</phase>
						<goals>
							<goal>copy-resources</goal>
						</goals>
						<configuration>
							<outputDirectory>${basedir}\target\classes\core\object\application\</outputDirectory>
							<resources>
								<resource>
									<directory>${basedir}\src\main\resources\</directory>
									<includes>
										<include>jaxb.properties</include>
									</includes>
								</resource>
							</resources>
						</configuration>
					</execution>
				</executions>
			</plugin>
But it doesn't work.
So I tried to put this on my web.xml (Server)
    <env-entry>
    	<env-entry-name>javax.xml.bind.JAXBContext</env-entry-name>
    	<env-entry-type>java.lang.String</env-entry-type>
    	<env-entry-value>org.eclipse.persistence.jaxb.JAXBContextFactory</env-entry-value>
    </env-entry>
    <env-entry>
    	<env-entry-name>javax.xml.bind.context.factory</env-entry-name>
    </env-entry>
But it doesn't work anymore...
What's the best way make it work ?
Re: MOXy + Tomcat6 + Maven [message #898817 is a reply to message #898370] Fri, 27 July 2012 14:33 Go to previous message
Blaise Doughan is currently offline Blaise Doughan
Hello Jeremie,
Is your question essentially how to get the jaxb.properties file in the correct location (same package as the model classes) in the deployment archive?
-Blaise
Previous Topic:@MappedSuperclass with Generic types
Next Topic:Search Query Error
Current Time: Sat May 25 22:13:42 EDT 2013
Powered by FUDForum. Page generated in 0.01542 seconds
