Home » Eclipse Projects » Jubula » Setup Java applet application
icon5.gif  Setup Java applet application [message #897220] Mon, 23 July 2012 05:13 Go to next message
Ba Ba is currently offline Ba Ba
I want to setup a java applet application into Jubula.
Can someone guide me step by step to activate my application?
Also is there any configuration for Java plugin?
thanks
[Updated on: Mon, 23 July 2012 05:27]
Report message to a moderator
Re: Setup Java applet application [message #898286 is a reply to message #897220] Thu, 26 July 2012 02:42 Go to previous messageGo to next message
Alexandra Schladebeck is currently offline Alexandra Schladebeck
I'm afraid I don't have any experience with applets and Jubula - I'm not sure in what sort of constellations they work or don't work. The best thing to do would be to do the cheat sheets (startable from the help menu) and see what you can figure out from there.
Alex
Re: Setup Java applet application [message #898345 is a reply to message #898286] Thu, 26 July 2012 05:06 Go to previous message
Alex - Thank you for your answer.
Currently I cant activate the applet - do you know if Jubula support java applet?
thanks
[Updated on: Thu, 26 July 2012 07:27]
Previous Topic:Check the properties of the GEF components
Next Topic:"Renderer not Supported" Error
Current Time: Mon May 20 17:19:31 EDT 2013
Powered by FUDForum. Page generated in 0.01982 seconds
