Home » Language IDEs » PDT » Exclusion rules for validators in Juno
Exclusion rules for validators in Juno [message #898245] Thu, 26 July 2012 00:39 Go to next message
Piotr Łyczba is currently offline Piotr Łyczba
recently I upgraded my eclipse to Juno. I use IDE for PHP development (Symfony Eclipse Plugin) and I noticed that exclusion rules for validators dissapered from Project Settings comparing to Indigo. I really need this functionality due to large number of test xml files (stored in "Tests" direcories) that contains that errors' triggers in my project.
How can I get back that useful settings?
PS: I added exclude rules in PHP Build Path -> Source Folders but it doesn't change anything in matter of validation.
PS2: I am using Eclipse 4.2 with PDT 3.0 from official Juno Software Site.
[Updated on: Thu, 26 July 2012 00:40]
Report message to a moderator
Re: Exclusion rules for validators in Juno [message #898364 is a reply to message #898245] Thu, 26 July 2012 05:31 Go to previous messageGo to next message
Toshihiro Izumi is currently offline Toshihiro Izumi
Try installing "Eclipse Web Developer Tools" or "Eclipse XML Editors and Tools".
Because it is necessary to have org.eclipse.wst.validation.ui. PDT doesn't require/install it.
Re: Exclusion rules for validators in Juno [message #898659 is a reply to message #898364] Fri, 27 July 2012 02:21 Go to previous messageGo to next message
@Toshihiro Izumi
Thanks for your answer. It partialy solved my problem. Unfortunately it seems that ** placeholder in "**/Tests" folder exclusion rule isn't supported the same way like in "Build Paths" options. Is it any other way to define folder pattern in one rule? I would avoid adding rules for every single folder in each project.
Re: Exclusion rules for validators in Juno [message #898848 is a reply to message #898659] Fri, 27 July 2012 20:51 Go to previous message
Validation comes from WTP. You could claim against WTP.
Previous Topic:Downloadables (status on 2012/07/24)
Next Topic:Pb on ubuntu 12.04 and code assist
Current Time: Fri May 24 18:09:14 EDT 2013
Powered by FUDForum. Page generated in 0.01561 seconds
