Home » Eclipse Projects » P2 » DBTools and P2(Attempt to convert a set of plug-ins to be P2 Compatible)
icon9.gif  DBTools and P2 [message #898095] Wed, 25 July 2012 15:10 Go to next message
David Coley is currently offline David Coley
Please forgive me if this is in the wrong forum. This is my first posting to this site. I have read wiki after wiki, googled and read the forum but cannot seem to get the answer I need.
I have a requirement to take the IBM DBTool which is a stand alone eclipse variant, and take the required Features / Plug-ins into our custom internal P2 Repository.
I am trying to make it so that developers do not need to have multiple versions of Eclipse installed.
Right now if you install the IBM DB Tools tool using the Install Manager it comes with, it create PLUGINS and FEATURES directories. Inside the base of this is a repository.config which has "ProfileLayout=P1"
The features do not have any jar files in them... only feature.xml files. The Plug-in folders have Source and Compiled Jar files in them.
Any pointers on how (or if it is possible) to get this working as a internal update site would be greatly appreciated.
Re: DBTools and P2 [message #898186 is a reply to message #898095] Wed, 25 July 2012 20:49 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik Lindberg
You can basically build a p2 update site with PDE Build, Buckminster or
Tycho - which one to pick depends on what suits you / your organization.
Do you need headless builds and are not already using PDE Build, then I
suggest you use one of the other two which both can build a p2 update
site using Eclipse IDE, or in headless fashion.
Once you produced a p2 update site, simply publish it on a web server.
If you are uncertain about how all the parts fit together (features,
plugins, fragments, products, p2 update sites, update managers, etc.
etc.) then I recommend the Introductory chapters of the "Bucky Book"
available from the Buckminster update site.
How to actually use PDE, Buckminster or Tycho are topics for their
respective forums.
Hope that helps.
Best Regards
- henrik
Re: DBTools and P2 [message #898306 is a reply to message #898095] Thu, 26 July 2012 03:29 Go to previous message
Klaus Kopecz is currently offline Klaus Kopecz
Hi David,
You might consider using the headless p2 publisher
http://wiki.eclipse.org/Equinox/p2/Publisher
Based on that you could transform, e.g., a complete Eclipse installation (with eclipse.exe and feature/plugin folders) into a p2 repository ("update site"). The "Features and Bundles Publisher" should do this:
http://wiki.eclipse.org/Equinox/p2/Publisher#Features_And_Bundles_Publisher_Application
Previous Topic:Can't get P2 to load remote repository
Next Topic:get my repository in p2.inf as default in 'Available software sites'
Current Time: Tue Jun 18 03:31:48 EDT 2013
Powered by FUDForum. Page generated in 0.01714 seconds
