Home » Language IDEs » CDT » eglplatform.h issue(eclipse can use egl functions but doesnt recognize the eglplatform variables declared in them)
eglplatform.h issue [message #897953] Wed, 25 July 2012 09:49
jan schuerman is currently offline jan schuerman
Im my testing application i am trying to native use open GLES but when calling egl functions that require eglplatform.h variables or using those variables themselves eclipse puts erros these are the problems:
m_Display = eglGetDisplay(EGL_DEFAULT_DISPLAY);
m_Surface = eglCreateWindowSurface(m_Display, lConfig,
m_Application->window, NULL);
nvalid arguments ' Candidates are: void * eglGetDisplay(?)
Type 'EGL_DEFAULT_DISPLAY' could not be resolved
Invalid arguments ' Candidates are: void * eglCreateWindowSurface(void *, void *, ?, const int *)
EGL_DEFAULT_DISPLAY is declared in egl.h but it is based on a variable from eglplatform.h so also isnt accepted,
I`m at a los of how to fix this, ive tried including eglplatform.h itself but it doesnt change anything
greets
Previous Topic:Save run-time warnings in Console window
Next Topic:[SOLVED] Debugger very slow (~ 10 sec between two steps) !
Current Time: Fri May 24 13:34:12 EDT 2013
Powered by FUDForum. Page generated in 0.01884 seconds
