| Re: Updating Xtext 2.2.1 to 2.3.0 [message #898369 is a reply to message #897940] |
Thu, 26 July 2012 05:34   |
Aaron Digulla Messages: 234 Registered: July 2009 Location: Switzerland |
How about updating the Eclipse plug-ins? Did anyone manage that? Is/should it be possible?
I get lots of errors from p2 because many Xtext bundles are singletons and Eclipse refuses to update them :-/ Two examples are the docs and examples:
Xtext documentation
Cannot complete the install because of a conflicting dependency.
Software being installed: Xtext Documentation 2.3.0.v201206120633 (org.eclipse.xtext.docs.feature.group 2.3.0.v201206120633)
Software currently installed: Xtext SDK 2.2.1.v201112130541 (org.eclipse.xtext.sdk.feature.group 2.2.1.v201112130541)
Only one of the following can be installed at once:
Xtext Documentation 2.3.0.v201206120633 (org.eclipse.xtext.doc 2.3.0.v201206120633)
Xtext Documentation 2.2.1.v201112130541 (org.eclipse.xtext.doc 2.2.1.v201112130541)
Cannot satisfy dependency:
From: Xtext Documentation 2.3.0.v201206120633 (org.eclipse.xtext.docs.feature.group 2.3.0.v201206120633)
To: org.eclipse.xtext.doc [2.3.0.v201206120633]
From: Xtext SDK 2.2.1.v201112130541 (org.eclipse.xtext.sdk.feature.group 2.2.1.v201112130541)
To: org.eclipse.xtext.xtext.ui.feature.group [2.2.1.v201112130541]
From: Xtext Xtext UI 2.2.1.v201112130541 (org.eclipse.xtext.xtext.ui.feature.group 2.2.1.v201112130541)
To: org.eclipse.xtext.doc [2.2.1.v201112130541]
Xtext examples:
Software being installed: Xtext Examples 2.3.0.v201206120633 (org.eclipse.xtext.examples.feature.group 2.3.0.v201206120633)
Software currently installed: Xtext Xtext UI 2.2.1.v201112130541 (org.eclipse.xtext.xtext.ui.feature.group 2.2.1.v201112130541)
Xtext Ecore Ui Support 2.3.0.v201206120633 (org.eclipse.xtext.ui.codetemplates 2.3.0.v201206120633)
Xtext Ecore Ui Support 2.2.1.v201112130541 (org.eclipse.xtext.ui.codetemplates 2.2.1.v201112130541)
From: Xtext Examples 2.3.0.v201206120633 (org.eclipse.xtext.examples.feature.group 2.3.0.v201206120633)
To: org.eclipse.xtext.ui.feature.group [2.3.0,2.4.0)
From: Xtext UI 2.2.1.v201112130541 (org.eclipse.xtext.ui.feature.group 2.2.1.v201112130541)
To: org.eclipse.xtext.ui.codetemplates [2.2.1.v201112130541]
From: Xtext UI 2.3.0.v201206120633 (org.eclipse.xtext.ui.feature.group 2.3.0.v201206120633)
To: org.eclipse.xtext.ui.codetemplates [2.3.0.v201206120633]
To: org.eclipse.xtext.ui.feature.group [2.2.1,2.3.0)
Xtext base:
Software being installed: Xbase 2.3.0.v201206120633 (org.eclipse.xtext.xbase.feature.group 2.3.0.v201206120633)
Software currently installed: Xtext UI 2.2.1.v201112130541 (org.eclipse.xtext.ui.feature.group 2.2.1.v201112130541)
Xtext UI Core 2.3.0.v201206120633 (org.eclipse.xtext.ui 2.3.0.v201206120633)
Xtext UI Core 2.2.1.v201112130541 (org.eclipse.xtext.ui 2.2.1.v201112130541)
To: org.eclipse.xtext.ui [2.2.1.v201112130541]
From: Xbase 2.3.0.v201206120633 (org.eclipse.xtext.xbase.feature.group 2.3.0.v201206120633)
To: org.eclipse.xtext.xbase.ui [2.3.0.v201206120633]
From: Xbase UI 2.3.0.v201206120633 (org.eclipse.xtext.xbase.ui 2.3.0.v201206120633)
To: bundle org.eclipse.xtext.ui [2.3.0,3.0.0)
Why can't I install two versions of the docs?
A. Digulla
[Updated on: Thu, 26 July 2012 05:39] Report message to a moderator
| Re: Updating Xtext 2.2.1 to 2.3.0 [message #898504 is a reply to message #898498] |
Thu, 26 July 2012 09:48   |
Well, the error message says:
so basically, I can't update Xtext Documentation because Xtext SDK wants the old version of the docs.
But I get a similar error when I try to update Xtext SDK :-/ I just tried to come up with a shorter error message. I guess I'll have to try again.
[Updated on: Thu, 26 July 2012 09:53] Report message to a moderator
| Re: Updating Xtext 2.2.1 to 2.3.0 [message #899015 is a reply to message #898487] |
Mon, 30 July 2012 03:43  |
Sebastian Zarnekow Messages: 2788 Registered: July 2009 |
If you repackage Xtext features on an own update site, you have to make
sure that you include all features. Otherwise the update procedure won't
work since not all features that were previously installed can be
updated if you miss one of those.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 26.07.12 15:20, schrieb Aaron Digulla:
> Sebastian Zarnekow wrote on Thu, 26 July 2012 13:46
>> Sure. "Check for updates" should do the trick.
> Damn.
>> That indicates an inconsistent manual selection of to-be-installed
>> features.
> In my case, it means that I must not merge your p2 update site with
> other update sites into one big update site :(
> I probably could use a composite p2 repo but that causes a lot of
> unnecessary traffic. *sigh*
> What I don't understand: How can p2 update the bundles from your site
> (even though they are singletons) but not from mine?? Is there some
> trick to tell p2 that it can update a singleton?
> A. Digulla
FUDForum. Page generated in 0.02308 seconds
