Home » Modeling » TMF (Xtext) » [Xtend] Shortcut for switching between xtend and java
[Xtend] Shortcut for switching between xtend and java [message #897927] Wed, 25 July 2012 09:02 Go to next message
Kevin Wiedener is currently offline Kevin Wiedener
I'm pretty sure there is a shortcut for switching between the generated java code and the xtend class, but I was unable to find it either in the manual or in the internet.
Maybe some of you know the shortcut?
Many thanks,
Kevin
Re: [Xtend] Shortcut for switching between xtend and java [message #897961 is a reply to message #897927] Wed, 25 July 2012 10:03 Go to previous message
Sebastian Zarnekow is currently offline Sebastian Zarnekow
There is no such shortcut. Please file a ticket and describe why the
'Generated code view' is not sufficient.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 25.07.12 15:03, schrieb Kevin Wiedener:
> Many thanks,
> Kevin
Previous Topic:.ecore models in linked folders not indexed
Next Topic:Use xtend2 and xbase-based DSL in GWT application client
Current Time: Mon May 20 04:03:53 EDT 2013
Powered by FUDForum. Page generated in 0.01654 seconds
