| Focus on a Text in a Dialog [message #897753] |
Wed, 25 July 2012 04:23  |
Hi guys,
I am trying to set the focus of my custom Dialog and I am not able to do it. I have try it in different ways, but I've never found the way to do it.
The last thing I tried is add a ControlListener to my shell in order to perform a setFocus when the Dialog is resized as this:
shell.addControlListener(new ControlAdapter() {
public void controlResized(ControlEvent e) {
initializeBounds();
shell.getDisplay().timerExec(2000, new Runnable() {
public void run() {
top.setFocus();
txtAlias.setFocus();
But without results...
Do you know how can I do it?
Thanks in advance.
| Re: Focus on a Text in a Dialog [message #912893 is a reply to message #898393] |
Fri, 14 September 2012 07:09   |
Is there a request for this yet, I could not find it?
Am 26.07.2012 12:17, schrieb Ivan Furnadjiev:
> Hi David,
> just checked it more precisely. Focusing is working with Chrome... but
> not in other browsers (widget is highlighted, but can't type in it).
> Please open a bugzilla about this issue.
> Ivan
> On 7/26/2012 11:46 AM, David Casas wrote:
>> Hi Ivan,
>> I have checking eclipse controls demo and I am not seeing setFocus is
>> working. On the http://rap.eclipsesource.com/rapdemo/examples#dialog,
>> if you click on Login dialog you won't see focus at all. However, if
>> we see the code, we will see:
>> private void initilizeDialogArea() {
>> if( message != null ) {
>> mesgLabel.setText( message );
>> if( username != null ) {
>> userText.setText( username );
>> userText.setFocus();
>> Do I have to open a bug?
| Re: Focus on a Text in a Dialog [message #913111 is a reply to message #912893] |
Fri, 14 September 2012 15:54  |
Rüdiger Herrmann Messages: 551 Registered: July 2009 |
Bug 386053 - [Text] setFocus does not work under some constellation
https://bugs.eclipse.org/bugs/show_bug.cgi?id=386053
>> Hi David,
>> Thanks,
>> Ivan
>>> Hi Ivan,
Rüdiger Herrmann
http://codeaffine.com
FUDForum. Page generated in 0.07441 seconds
