Home » Modeling » TMF (Xtext) » How do I filter the result of AbstractDeclarativeScopeProvider.delegateGetScope()?
How do I filter the result of AbstractDeclarativeScopeProvider.delegateGetScope()? [message #897741] Wed, 25 July 2012 03:57 Go to next message
Aaron Digulla is currently offline Aaron Digulla
I have a language which allows to extend base models:
lib B extends A {}
When I try code completion after "extends", Xtext offers me "B" which doesn't make sense. So I wrote a method in ModelScopeProvider which extends AbstractDeclarativeScopeProvider:
public IScope scope_Lib_baseLib( Lib lib, EReference ref ) {
IScope delegateScope = delegateGetScope( lib, ref );
... remove "lib" from delegateScope ...
return delegateScope;
How do remove lib from delegateScope?
A. Digulla
Re: How do I filter the result of AbstractDeclarativeScopeProvider.delegateGetScope()? [message #897745 is a reply to message #897741] Wed, 25 July 2012 04:04 Go to previous messageGo to next message
Okay, I'm one step further:
        Predicate<IEObjectDescription> filter = new Predicate<IEObjectDescription>() {
            public boolean apply( IEObjectDescription input ) {
                return !input.getEObjectOrProxy().equals( lib );
        result = new FilteringScope( delegateScope, filter  );
        return result;
Is this the correct way to compare an IEObjectDescription and an EObject to see whether they are equal?
A. Digulla
[Updated on: Wed, 25 July 2012 04:14]
Report message to a moderator
Re: How do I filter the result of AbstractDeclarativeScopeProvider.delegateGetScope()? [message #897790 is a reply to message #897745] Wed, 25 July 2012 05:01 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian Dietrich
Hi for perf reasons: why dont you simply compare the libs qualified
name (I qualified name provider) with the eobjectdesxriptions
qualified name
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: How do I filter the result of AbstractDeclarativeScopeProvider.delegateGetScope()? [message #897858 is a reply to message #897790] Wed, 25 July 2012 06:24 Go to previous messageGo to next message
Christian Dietrich wrote on Wed, 25 July 2012 11:01
qualified name
Two reasons:
1. I'm not sure how Xtext builds qualified names and whether it's guaranteed that the same symbols have the same name (someone said EMF proxies don't have qualified names)
2. Because I don't know how to get a qualified name for an EObject.
A. Digulla
Re: How do I filter the result of AbstractDeclarativeScopeProvider.delegateGetScope()? [message #897863 is a reply to message #897858] Wed, 25 July 2012 06:28 Go to previous messageGo to next message
I said: ask the ieobjectdescription for its qualifiedname and use an
injected Iqualifiednameprovider to obtain the qualifiedname of your
local eobject
Re: How do I filter the result of AbstractDeclarativeScopeProvider.delegateGetScope()? [message #897901 is a reply to message #897863] Wed, 25 July 2012 07:56 Go to previous messageGo to next message
Is this code correct, then?
    @Inject
    private IQualifiedNameProvider qualifiedNameProvider;
        final QualifiedName nameFilter = qualifiedNameProvider.getFullyQualifiedName( lib );
                return !nameFilter.equals( input.getQualifiedName() );
        IScope result = new FilteringScope( delegateScope, filter  );
        return result;
Re: How do I filter the result of AbstractDeclarativeScopeProvider.delegateGetScope()? [message #897917 is a reply to message #897901] Wed, 25 July 2012 08:31 Go to previous messageGo to next message
Yes
Re: How do I filter the result of AbstractDeclarativeScopeProvider.delegateGetScope()? [message #897939 is a reply to message #897917] Wed, 25 July 2012 09:29 Go to previous message
Thanks a lot Smile After my horrible experience earlier this week, I'm overcautious.
A. Digulla
Previous Topic:semantic highlighting stopped working for comments ?
Next Topic:.ecore models in linked folders not indexed
Current Time: Sun May 19 05:47:52 EDT 2013
Powered by FUDForum. Page generated in 0.02019 seconds
