Home » Newcomers » Newcomers » Stopping the default search commands from loading(Eclipse rcp, org.eclipse.search.searchPages)
Stopping the default search commands from loading [message #897345] Mon, 23 July 2012 12:37 Go to next message
Thomas Sörensen is currently offline Thomas Sörensen
I have a Eclipse RCP app that I have created 2 searchpages and added them to the org.eclipse.search.searchPages extension point. These search pages are visible and work just fine after running the app and clicking on the search menu and then the search command.
However there are a some items in the menu that shouldn't be visible. Like the File search and java search pages.
I extracted the jar files that are part of the org.eclipse.search package and discovered that there is a plugin.xml in the jar file that adds all of these commands and pages that I don't whant.
How do I remove these so that only my own searchpages are visible?
Even better would be to stop it from loading completly.
I have been able to remove the search menu completely but it seems impossible to access and remove the commands themselves. But even if I remove these items on runtime the pages will still be loaded won't they?
Re: Stopping the default search commands from loading [message #897502 is a reply to message #897345] Tue, 24 July 2012 06:13 Go to previous message
Dani Megert is currently offline Dani Megert
On 23.07.2012 18:37, Thomas Sörensen wrote:
> Hi I have a Eclipse RCP app that I have created 2 searchpages and
> Like the File search and java search pages. I extracted the jar files
This is not true: e.g. the Java stuff comes from the
'org.eclipse.jdt.ui' plug-ins, which you probably don't need for your RCP.
You can hide them using the 'org.eclipse.ui.activities' extension point.
Dani
Previous Topic:zxing
Next Topic:i can´t run simple code, i get the same error once and again
Current Time: Wed May 22 11:14:54 EDT 2013
Powered by FUDForum. Page generated in 0.16931 seconds
