| AnchorLayout [message #897433] |
Tue, 24 July 2012 02:56  |
Ossama Nasser Messages: 5 Registered: July 2012 |
Junior Member |
Hello this is my first post at eclipse forums so I hope you like it
I've been thinking a lot about java swing and how it's easy to build GUIs in other IDEs (like Delphi and Visual Studio) and how hard it is (for me at least) in NetBeans and eclipse .
So it hit me : why don't I design my own layout manager that acts like the other IDEs.
But dreaming is easy, I designed the anchor layout manager and I had few problems :
What's good about it :
It uses size and location to position a visible component on the container (like absolute layout) and it uses easily defined anchors to set the problem of resizing and repositioning when the container size changes , how ?
When you add a component to the container you add an instance of the class AnchorConstrains which in turn asks you to define the anchor (Top ,Left ,Right ,Bottom and it's combinations) along with location and size ,and based on the anchors the layout define resizing and/or repositioning
Despite the layout manager changes the size of components in some cases it cannot make components smaller than minimum size or bigger than maximum size
If we define minimum size with 0 (width and/or height) the layout manager doesn't use it ,so when we reach at resizing the case where component size can be zero or event negative the layout manager takes the previous size which in this case is positively positive
And to override max size lock you simply have to make the value of maximum size either big enough to never be reached by preferred size or simply 0
I do believe that some things sound mysterious to you because I'm not that good at explaining with words but the way the layout manager works is easy and simple and I doubt you will have a problem with it
What's bad about it :
Though I searched online a lot (but not enough apparently) to know how to define the layout manger to work with windowBuilder ,I failed , so here it is how the layout manager must operate in windowBuilder :
o Like absolute and Group layouts we must be able to drag and drop components on the container defining the constrains of the location and size (anchor is set default to TOP LEFT) with the ability to change them along with anchors as the user wishes
o Anchor layout cannot be shared : windowBuilder creates a JPanel and replaces the JFrame content pane with it ,checking the parents does not work properly because the layout manager needs the size of the container so when we pass the content pane as the target the size will be (0,0) so all the calculations will be wrong
So the bottom line is I have these to problems for now ,can I count on you to help ?
I have attached the source files with a simple demo and JavaDoc
Attachment: OSwing.rar
(Size: 61.60KB, Downloaded 32 times)
| Re: AnchorLayout [message #897666 is a reply to message #897433] |
Tue, 24 July 2012 23:31   |
Konstantin Scheglov Messages: 547 Registered: July 2009 |
I'm not quite sure what question you have.
You could look how Group layout or MigLayout are done to see how to add support for new layout manager.
Copy it, change ID's, clean up everything what you don't need and start adding specific support for your manager.
If you have any specific questions, ask them.
Konstantin Scheglov,
Google, Inc.
| Re: AnchorLayout [message #915423 is a reply to message #899240] |
Mon, 17 September 2012 04:36   |
Junior Member |
Guys :
Is there a link where I can download windowbuilder source code in manner of compressed file ,because when I looked I found the svn link only ?
one more think are you planing to publish some kind of understandable tutorial about writing components for windowbuilder as well as documentation to know what to do ?
[Updated on: Mon, 17 September 2012 04:37] Report message to a moderator
FUDForum. Page generated in 0.02239 seconds
