Home » Modeling » Graphiti » Expand/Collapse Custom Feature
Expand/Collapse Custom Feature [message #897246] Mon, 23 July 2012 07:51 Go to next message
Surya Kathayat is currently offline Surya Kathayat
Member
I am trying to write a custom feature to a Task node in graphical editor.
The feature shall do the following.
- Update the icon of collapse context button dynamically i.e. after the node is collabpse expladable icon shall be shown.
- When expanded some extra nodes will be added/shown in adiagram editor. For example in the attached figure, when "expand" on "X" node is clicked, then nodes "A", "B" and links X->A, X->B will be shown. The case will be opposite on collapse.
index.php/fa/10807/0/
The following is execute method of my custom feature class. The question is how can I add/delete nodes and links to the diagram from the "execute" method of my custom feature class?
    public void execute(ICustomContext context) {
          MessageDialog.openInformation(PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShell(), "Information",
          "The 'Collapse Feature' is intentionally not implemented yet.");
          PictogramElement[] pes = context.getPictogramElements();
          if (pes != null && pes.length == 1) {
              Object bo = getBusinessObjectForPictogramElement(pes[0]);
              if (bo instanceof Task) {
              	Task task = (Task) bo;
              	if((task.getHasSubtasks() !=null) && task.getHasSubtasks()==1){
              		// set the icon flag
              		this.isExpanded = true;
              		// get db connection
              		TaskDaoProxy taskDaoProxy = new TaskDaoProxyImpl(task.getIdCenterName());
              		// I will get list of links and tasks nodes here
              		List<Link> links = taskDaoProxy.getChildTaskLinksForGraph(Integer.valueOf(task.getMcTaskId()), false);
              		// then HOW TO ADD THEM IN DIAGRAM ???
              	else {
              		 this.isExpanded = false;
              	// update pictogram
                updatePictogramElement(pes[0]);
                // set the done flag
                this.hasDoneChanges = true;
    public boolean hasDoneChanges() {
           return this.hasDoneChanges;
[Updated on: Mon, 23 July 2012 07:52]
Report message to a moderator
Re: Expand/Collapse Custom Feature [message #897256 is a reply to message #897246] Mon, 23 July 2012 08:32 Go to previous messageGo to next message
Matthias Gorning is currently offline Matthias Gorning
Member
I assume that you already have an add feature for your Task nodes.
Hence you can simply add these lines to the execute method of your custom feature:
AreaContext areaContext = new AreaContext();
areaContext.setLocation(20, 20);
areaContext.setSize(100, 100);
AddContext addContext = new AddContext(areaContext, <your business object>); // Tasks or Links
addContext.setTargetContainer(getDiagram());
getFeatureProvider().addIfPossible(addContext);
Re: Expand/Collapse Custom Feature [message #897271 is a reply to message #897256] Mon, 23 July 2012 09:21 Go to previous messageGo to next message
Member
Thank you Matthias. Razz
It works as you said.
How can I change the icon of collapse context button dynamically?
BR
Surya
Re: Expand/Collapse Custom Feature [message #900759 is a reply to message #897271] Wed, 08 August 2012 08:13 Go to previous message
Michael Wenz is currently offline Michael Wenz
You should be able to do that by simply setting a new image id for the image
object (the string identifier defined in the image provider).
Michael
Previous Topic:delete confirmation dialog
Next Topic:Diagram Layout
Current Time: Tue May 21 11:34:13 EDT 2013
Powered by FUDForum. Page generated in 0.09583 seconds
