Home » Newcomers » Newcomers » sempiternal HelloWorld(can't run the basic HelloWorld)
sempiternal HelloWorld [message #897014] Fri, 20 July 2012 14:54 Go to next message
d. grens is currently offline d. grens
I've been using eclipse CDT for years I must now switch to java and installed the JDT version on Juno.
I first did a check with a classical HelloWorld program which works fine on my linux console
When I try to compile and run on eclipse I've got the error in the Problems window:
Archive for required library: '/usr/lib64/jvm/java-1.6.0-openjdk-1.6.0/jre/lib/ext/gnome-java-bridge.jar' in project 'Hello World' cannot be read or is not a valid ZIP file Hello World Build path Build Path Problem
and if I run it nevertheless I've got on the console window:
Exception in thread "main" java.lang.NoClassDefFoundError: HelloWorld
Caused by: java.lang.ClassNotFoundException: HelloWorld
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:321)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
at java.lang.ClassLoader.loadClass(ClassLoader.java:266)
Could not find the main class: HelloWorld. Program will exit.
I'm new in java and I'm pretty sure it's something about the launch or(and) build configuration but the configuration options in JDT seems to me numerous and cryptic
When I followed for example the instructions from:
www.cis.upenn.edu/~matuszek/cit591-2004/Pages/starting-eclipse.html
to create a launch configuration it still gives me the exact same errors
the HelloWorld compiles and works fine within a linux shell console so it should not be a true error with the .jar file being invalid
Can anybody explain me my probably obvious newbee error ?
Re: sempiternal HelloWorld [message #897018 is a reply to message #897014] Fri, 20 July 2012 15:06 Go to previous messageGo to next message
David Wegener is currently offline David Wegener
It looks like you installed something that put a Java extension in your jdk. The gnome-java-bridge.jar isn't a normal jar included in a JDK installation. Eclipse must have picked it up because it is in the lib/ext folder.
You can try removing it from the jre configuration. Go to Window->Preferences->Java->Installed JREs. Select the JRE you are using and edit it. Remove the entry for gnome-java-bridge.jar.
Re: sempiternal HelloWorld [message #897125 is a reply to message #897018] Sun, 22 July 2012 03:08 Go to previous message
I started to dig around the .jar problem
and it was in fact a bug of openjdk on some linux-opensuse systems:
the
must be present on the system but in this release it is read forbidden for anybody but root (???)
just changing it's mode to rwx-r--r-- solved it
Thanks for the hint, it was trully a jar pb
PS: But I still don't understand why javac HelloWorld.java + java HelloWorld works and eclipse didn't want to compile run the same program ?
Previous Topic:Downloaded Juno package but after install and running it says it is Indigo
Next Topic:Change Log for Eclipse
Current Time: Sun May 19 19:17:16 EDT 2013
Powered by FUDForum. Page generated in 0.02754 seconds
