Home » Modeling » Epsilon » XMI to HUTN bridge
XMI to HUTN bridge [message #534368] Tue, 18 May 2010 17:01 Go to next message
Enrico Schnepel is currently offline Enrico Schnepel
I would like to create a hutn file from an existing .ecore model. I
could not find any menu entry where I could invoke the bridge.
Enrico
Re: XMI to HUTN bridge [message #534391 is a reply to message #534368] Tue, 18 May 2010 20:27 Go to previous messageGo to next message
Dimitrios Kolovos is currently offline Dimitrios Kolovos
Hi Enrico,
I don't think there's such a menu entry. Could you please file an
enhancement request for this? Off the top of my head, I think a
workaround is to rename the .ecore into .model and then create a .hutn
out of it.
Dimitris
> Thanks
> Enrico
Re: XMI to HUTN bridge [message #536383 is a reply to message #534368] Thu, 27 May 2010 18:02 Go to previous messageGo to next message
No real name is currently offline No real name
You can also create a new .hutn file which is initially empty and add the following:
@Spec {
metamodel "yourModelNamespaceName" {
nsUri: "yourModelNamespaceName"
package {
YourTopLevelModel "YourTopLevelModel1" {
Then right-click on the .hutn file and select HUTN->Generate Model.
Make sure you right-click on the .ecore file and select Register EPackages, otherwise you will get errors in your .hutn about the metamodel not being found.
Re: XMI to HUTN bridge [message #589305 is a reply to message #534368] Tue, 18 May 2010 20:27 Go to previous messageGo to next message
Hi Enrico,
out of it.
Dimitris
> Thanks
> Enrico
Re: XMI to HUTN bridge [message #589425 is a reply to message #534368] Thu, 27 May 2010 18:02 Go to previous messageGo to next message
@Spec {
package {
Re: XMI to HUTN bridge [message #897106 is a reply to message #534368] Sat, 21 July 2012 17:45 Go to previous message
Jay Norwood is currently offline Jay Norwood
I noticed that the current version of epsilon does have an HUTN context menu item to generate an hutn instance from a previous emf xmi instance. This worked well for me.
The conversion program apparently expects your xmi model instance to have suffix .model, so you need to rename your xmi file with that suffix, then right click on it in the browser and select the HUTN generation from the context menu.
After previously trying to guess the correct format, this was very helpful in converting a large hutn example that I could evaluate. Nice...
[Updated on: Sat, 21 July 2012 17:46]
Report message to a moderator
Previous Topic:Running Epsilon using any OSGi implementatino
Next Topic:[eugenia] is there a way?
Current Time: Wed May 22 04:47:15 EDT 2013
Powered by FUDForum. Page generated in 0.07637 seconds
