Home » Language IDEs » Java Development Tools (JDT) » @NonNull Lists
@NonNull Lists [message #896835] Fri, 20 July 2012 00:40 Go to next message
I've just started using the Juno @NonNull annotations. Great for
deblurring APIs.
But as with any good facility, I want more. I see that @NonNull fields
are imminent (and essential). But what about
Null variable arguments
@NonNull String... seems to mean a non-null array of arguments rather
than an array of @NonNull arguments.
Lists of @NonNull.
I want to do List<@NonNull String> so that I don't need to null-check
iteration elements.
And is there a way to import an auxiliary set of declarations for
unannotated code such as
@NonNull String String.trim();
Ed Willink
Re: @NonNull Lists [message #896899 is a reply to message #896835] Fri, 20 July 2012 06:59 Go to previous messageGo to next message
Stephan Herrmann is currently offline Stephan Herrmann
Hi Ed,
thanks for asking.
Ed Willink wrote on Fri, 20 July 2012 06:40
I've just started using the Juno @NonNull annotations. Great for deblurring APIs.
I want more, too Smile
I see that @NonNull fields are imminent (and essential).
That's currently in beta status (available for early access), please have a look at http://wiki.eclipse.org/JDT_Core/Null_Analysis/Beta
We went back and forth here, but decided that a full solution has to wait for JSR 308, at what time we'll be able to say things like
@Nullable String @Nonnull[] args; // array can be null, elements cannot
Lists of @NonNull.
iteration elements.
With JSR 308 this will be possible. Today that's just not valid Java syntax.
Here I don't have an excuse other than: not enough time. Please see https://bugs.eclipse.org/331651 for our plans in this regard.
Your list is right on, exactly the things that are in our pipe line. Regarding null annotations for fields we are explicitly asking for feedback regarding the current beta. The wiki page links to a bugzilla, please add your comments when you try it.
Stephan
Re: @NonNull Lists [message #897094 is a reply to message #896899] Sat, 21 July 2012 12:48 Go to previous message
Javin Paul is currently offline Javin Paul
Member
On related note, I am more than happy to see @NonNull annotation on Juno. Thank you guys for adding this feature. IntelliJ has there @NotNull and @Nullable from long time and this is something I really looking forward. If we can get the feature asked by @Ed Willink, it would be awesome.
Previous Topic:templates broken in juno
Next Topic:why my Eclipse IDE do not support Arabic and Farsi fonts?
Current Time: Tue May 21 06:00:55 EDT 2013
Powered by FUDForum. Page generated in 0.01555 seconds
