Home » Newcomers » Newcomers » Eclipse (jdbc) and mysql database(Cant connect)
Eclipse (jdbc) and mysql database [message #896401] Wed, 18 July 2012 05:57 Go to next message
Eru Iluva is currently offline Eru Iluva
Hello everyone
Started using eclipse and tried connecting to a local mysql database.
Used buildpath and added a new external source (the .jar) and created on my pc a classpath to the .jar file too.
The problem i have is, i dont get a error, so i cant figure out what im doing wrong. As far as i can tell its stuck on the "DriverManager.getConnection" line.
Could someone help me and tell me what im doing wrong?
import java.sql.*;
public class DbConnection {
		try{
			Class.forName("com.mysql.jdbc.Driver");
			Connection con = DriverManager.getConnection("jdbc:mysql://localhost:8080/test","root","password");
			PreparedStatement statement = con.prepareStatement("select * from teststuff");
			ResultSet result = statement.executeQuery();
			while(result.next()) {
				System.out.println(result.getInt(1)+" "+result.getString(2));
			result.close();
			statement.close();
			con.close();
		} catch(Exception ex) {
			System.out.println("****** EXCEPTION ****** -->" +ex);
Re: Eclipse (jdbc) and mysql database [message #896411 is a reply to message #896401] Wed, 18 July 2012 06:31 Go to previous messageGo to next message
Shyam Prakash is currently offline Shyam Prakash
Mysql db default port number is 3306 and 8080 is default http port. Try changing the port.
~Shyam
Re: Eclipse (jdbc) and mysql database [message #896415 is a reply to message #896411] Wed, 18 July 2012 06:40 Go to previous messageGo to next message
I could hit myself, so stupid. Yea didnt notice that.
Thanks, fixed.
Re: Eclipse (jdbc) and mysql database [message #897093 is a reply to message #896415] Sat, 21 July 2012 12:45 Go to previous message
Javin Paul is currently offline Javin Paul
Member
Though issue is fixed, I feel strange why your Java code doesn't throw Exception like normally in case of port clash it throw "java.net.BindException:address already in use" etc ??
Previous Topic:Can't install plugins in Juno
Next Topic:Eclipse installation on centos 6 server
Current Time: Sun May 26 05:21:32 EDT 2013
Powered by FUDForum. Page generated in 0.01568 seconds
