Home » Newcomers » Newcomers » Can't install plugins in Juno
Can't install plugins in Juno [message #895734] Sun, 15 July 2012 10:09 Go to next message
Hugo Duarte is currently offline Hugo Duarte
Hey guys,
I have just updated my Eclipse to Juno but I can't install plugins!
I tried to install Vrapper through the update site but the Finish button never becomes available in the wizard.
I also tried installing it by puttin the right files in /plugins and /features and no luck as well.
I am running Eclipse on Archlinux.
Please help.
Thank you
Re: Can't install plugins in Juno [message #895910 is a reply to message #895734] Mon, 16 July 2012 09:22 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
You should be installing eclipse from http://www.eclipse.org/downloads . Just unzip (not over an existing install) and go.
PW
Re: Can't install plugins in Juno [message #897072 is a reply to message #895910] Sat, 21 July 2012 08:58 Go to previous messageGo to next message
It is a better practice to install software from the distributions repositories.
Has anyone had this issue?
Re: Can't install plugins in Juno [message #897079 is a reply to message #895910] Sat, 21 July 2012 09:29 Go to previous message
It was an issue with my window manager (Awesome WM). It worked fine with a different one.
Previous Topic:insert php code in eclipse projekt
Next Topic:Eclipse (jdbc) and mysql database
Current Time: Wed May 22 09:36:02 EDT 2013
Powered by FUDForum. Page generated in 0.01749 seconds
