Home » Eclipse Projects » EGL Development Tools » SQLite3 Connection
SQLite3 Connection [message #896898] Fri, 20 July 2012 06:47 Go to next message
Bothwell Watadza is currently offline Bothwell Watadza
I am looking for basic instructions of how to connect my EGL application to
an SQLite3 database that is on my local machine
Bothwell
[Updated on: Fri, 20 July 2012 07:00]
Report message to a moderator
Re: SQLite3 Connection [message #897181 is a reply to message #896898] Sun, 22 July 2012 22:38 Go to previous message
fahua jin is currently offline fahua jin
Member
I did not try to use the SQLite, but it should be work if you have supplied right information for the DB connection. I found that the Eclipse also provides the SQLite connection wizard.
You could follow the steps in 'Create Database Connection' section of page http://wiki.eclipse.org/EDT:Tutorial:_RUI_With_DataBase_Lesson_3. Of course, you should select the SQLite and specify the correct JDBC driver. And in the EGL project, you should use this connection configured for SQLite.
Previous Topic:Screen Navigation Using EDT Eclipse
Next Topic:Debug environment
Current Time: Wed May 22 22:04:22 EDT 2013
Powered by FUDForum. Page generated in 0.01697 seconds
