| Re: Store a map in the properties of a pictogramelement [message #896891 is a reply to message #896588] |
Fri, 20 July 2012 06:22  |
Michael Wenz Messages: 1268 Registered: July 2009 Location: Walldorf, Germany |
Patrick,
I think it would be best not to store the connection directly in the
property, but instead to use a property like Name to identify a connection:
the property Name would be attached to the connection and the name value
could be used as the key in the map.
Michael
"Patrick Rütz" schrieb im Newsbeitrag news:ju7uab$9rj$1@xxxxxxxxe.org...
Hi Erdal,
i have a map mit map<connection, List<Anchor>>, because I had a
collapsefeature, but when I close the eclispe Plugin, the Map is set to
null and uncollapse. So I have to made my map persistent.
Patrick
FUDForum. Page generated in 0.02313 seconds
