| migrate from eclipse 3.3 to 4 [message #896666] |
Thu, 19 July 2012 06:38  |
ambika Missing name Messages: 8 Registered: June 2011 |
Junior Member |
I have to migrate from eclipse europa to Juno RCP . the code in 3.3 is working fine.What would be the steps to move it.This is what I tried:
created new plugins in Juno and moved all the src to it.
edited manifests manually to have the same changes as 3.3 plugins
when I export the product, An exe is generated but when i click on exe, I get the attached log generated in configuration folder.
I am new to Eclipse RCP.please help.If there are good links which can be followed to migrate, please share.
[Updated on: Thu, 19 July 2012 06:41] Report message to a moderator
| Re: migrate from eclipse 3.3 to 4 [message #896714 is a reply to message #896666] |
Thu, 19 July 2012 09:20   |
Joseph Carroll Messages: 156 Registered: May 2012 Location: Milwaukee, WI |
I started using developing RCP apps on the Helios release, and I am not certain what issues exist when migrating from 3.3. However, you best bet is to use the compatibility layer for starters. A good resource is Lars' tutorial [1].
As I said, I started developing in 3.6, but your best bet (IMHO) is to take incremental steps. First, I would focus on getting the app to run in 3.6 or 3.7. Then make the transition into the 4.2 compatibility layer. As of now, it is not reccommended to mix 3.x and 4.x plugins, there are too many issues. This is something that is being worked on for the service releases and 4.3. Lastly, take a look at some of the other links below to start getting a better feel for 4.x.
Take care,
JD
[1] http://www.vogella.com/articles/Eclipse4CompatibilityLayer/article.html
[2] http://www.eclipse.org/eclipse/development/porting/eclipse_4_2_porting_guide.php
[3] http://wiki.eclipse.org/Eclipse4/Eclipse_SDK_4.0_FAQ
| Re: migrate from eclipse 3.3 to 4 [message #899007 is a reply to message #896714] |
Mon, 30 July 2012 03:03   |
Junior Member |
Thanks JD,
the first link you gave was the key to my issue resolution
I somehow made the existing application work on Juno.Now I am stuck on P2 update site.I got the UI up.But 2 issue i face are:
1. in Available software sites, i dont get the site listed even though my p2.inf has a local repository added.
2. i changed one of the plugin version and did an export again.then i opened an old exported product and checked for new updates.But it is says nothing to update.I checked in content.xml and artifact.xml, both have lastest version of the plugin also added.
am i missing anything here?
regards
Ambika
[Updated on: Mon, 30 July 2012 03:08] Report message to a moderator
| Re: migrate from eclipse 3.3 to 4 [message #899309 is a reply to message #899216] |
Tue, 31 July 2012 08:41   |
Brian de Alwis Messages: 242 Registered: July 2009 |
It's hard to diagnose your problems without more detail. You might want to read through the p2 FAQ first though, as it includes se background and tips for diagnosing problems:
http://wiki.eclipse.org/P2/FAQ
The p2 installed along defaults to only showing categorized features; I'm not sure that you can assign categories when using the Eclipse Export functions. These defaults can be changed programmatically (and perhaps by entries in the preference_customization.ini).
Brian.
[Updated on: Tue, 31 July 2012 08:43] Report message to a moderator
| Re: migrate from eclipse 3.3 to 4 [message #899709 is a reply to message #899309] |
Thu, 02 August 2012 00:18  |
Junior Member |
Hi Brian
Thanks for your response.
My issue is that even though i have a p2.inf with the following entries
I am not able to get Available software sites with default site mentioned in p2.inf.
instructions.configure=\
org.eclipse.equinox.p2.touchpoint.eclipse.addRepository(name:My Update Site,type:0,location:file${#58}///C${#58}/Users/Desktop/myapp/JUNO/executable/repository);\
org.eclipse.equinox.p2.touchpoint.eclipse.addRepository(name:My Update Site,type:1,location:file${#58}///C${#58}/Users/Desktop/myapp/JUNO/executable/repository);
my build.xml has p2.gathering=true
here i expect 'My Update Site' to be displayed automatically in Available software sites.Not sure if my understanding is correct.
Mine is a feature based product.Please let me know if you need any more details
Ambika
FUDForum. Page generated in 0.04063 seconds
