Home » Modeling » Graphiti » Gerrit enabled for Graphiti Git repository
Gerrit enabled for Graphiti Git repository [message #896469] Wed, 18 July 2012 09:16
Michael Wenz is currently offline Michael Wenz
Hi all,
This is a short heads-up that Graphiti now uses the Eclipse Gerrit as code
review system (use your Eclipse Bugzilla user for login), all changes have
to go through it. This allows for easier contributions from the community,
so feel free to have a closer look...
The Gerrit-enabled repository URLs are:
ssh://userid@xxxxxxxxe.org:29418/gmp/org.eclipse.gmp.graphiti.git
https://git.eclipse.org/r/p/gmp/org.eclipse.gmp.graphiti.git
The page http://wiki.eclipse.org/Gerrit#Logon provides a description of how
to use the Eclipse Gerrit server including how to handle IP log relevant
contributions.
In short, you should do the following if you want to work on Graphiti
sources and enable pushing contributions:
- Add Graphiti to the list of your watched projects if you want to be
notified about changes (mandatory for committers) here:
https://git.eclipse.org/r/#/settings/projects
- Upload your SSH public keys to Gerrit if you want to use SSH here:
https://git.eclipse.org/r/#/settings/ssh-keys
- Configure your push specification for Gerrit:
o URL:
https://<dev_user>@git.eclipse.org/r/p/gmp/org.eclipse.gmp.graphiti.git
o The push specification is HEAD:refs/for/master
o Replace "master" with the branch you want to push to in case you want
to push a change to an older release or not the master branch, e.g. b0_9_x
o <dev_user>; is your development user (like mwenz)
o *Note: The password can and must be generated* here (the standard
development user password does not work!):
- When pushing to the main Git repository after the review, the IP clean
flag must be set. Please ensure that all requirements regarding IP
cleanliness are fulfilled!
All of this is also documented on our Wiki page at
http://wiki.eclipse.org/GMP/Graphiti#Repository
Here’s the Bugzilla for that change:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=377871
Michael
Previous Topic:TransactionalEditingDomain and Resource
Next Topic:Store a map in the properties of a pictogramelement
Current Time: Wed May 22 22:04:16 EDT 2013
Powered by FUDForum. Page generated in 0.02861 seconds
