Home » Eclipse Projects » Target Management » RSE won't let me edit remote files any more
RSE won't let me edit remote files any more [message #896356] Wed, 18 July 2012 03:35 Go to next message
Anna Torn is currently offline Anna Torn
This topic is related to one in here.
But I have a slightly different problem though.
I'm working with SSH only connection (with SCP File Srvices Incubation). It worked fine with Helios and after updating to Juno until yesterday when it stopped updating the files on the remote side, but deleting and browsing works perfect. Don't know if it have something with the Java version I'm running (it was Java 6, and now I've updated to 7, but problem's still the same). Also, Eclipse give an error at shutdown:
!ENTRY org.eclipse.ui.workbench 4 2 2012-07-18 13:16:21.373
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
!STACK 0
	at org.eclipse.rse.files.ui.resources.SystemEditableRemoteFile.partClosed(SystemEditableRemoteFile.java:1864)
	at org.eclipse.ui.internal.WorkbenchPage$17.run(WorkbenchPage.java:4390)
	at org.eclipse.ui.internal.WorkbenchPage.firePartClosed(WorkbenchPage.java:4388)
	at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart$1.handleEvent(CompatibilityPart.java:99)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
	at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
	at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
	at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
	at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
	at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
	at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:75)
	at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:57)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setWidget(UIElementImpl.java:248)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.unbindWidget(SWTPartRenderer.java:114)
	at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.disposeWidget(SWTPartRenderer.java:135)
	at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.disposeWidget(ContributedPartRenderer.java:285)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:840)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$3(PartRenderingEngine.java:768)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$8.run(PartRenderingEngine.java:763)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:748)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:801)
	at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.disposeWidget(ElementReferenceRenderer.java:122)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.stop(PartRenderingEngine.java:1074)
	at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:1118)
	at org.eclipse.ui.internal.Workbench.access$16(Workbench.java:998)
	at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1179)
	at org.eclipse.ui.internal.Workbench.close(Workbench.java:1177)
	at org.eclipse.ui.internal.Workbench.close(Workbench.java:1150)
	at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:1155)
	at org.eclipse.ui.internal.WorkbenchWindow.access$16(WorkbenchWindow.java:1135)
	at org.eclipse.ui.internal.WorkbenchWindow$10.run(WorkbenchWindow.java:1184)
	at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1182)
	at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:1194)
	at org.eclipse.ui.internal.WorkbenchWindow$6.close(WorkbenchWindow.java:441)
	at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer$10.shellClosed(WBWRenderer.java:562)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:98)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
	at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations.java:309)
	at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.java:1694)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4530)
	at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:341)
	at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
	at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2052)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
	at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2541)
	at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:498)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:4623)
	at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
	at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
	at java.lang.reflect.Method.invoke(Method.java:611)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
The most frightened part is that it worked and then it just doesn't.
Please, any ideas?
Re: RSE won't let me edit remote files any more [message #896371 is a reply to message #896356] Wed, 18 July 2012 04:20 Go to previous messageGo to next message
Martin Oberhuber is currently offline Martin Oberhuber
Your backtraces (from shutdown) seem to indicate a problem with the Eclipse 4.2 UI code. If RSE doesn't get notified properly about editor changes from the UI, we cannot upload the new file.
Can you try with Eclipse 3.8 instead of Eclipse 4.2 ?
If it works in 3.8 you should file a defect against Eclipse Platform UI, giving your backtraces.
Re: RSE won't let me edit remote files any more [message #896376 is a reply to message #896371] Wed, 18 July 2012 04:37 Go to previous messageGo to next message
Also I forgot to mention that the local copies in RemoteSystemTempFiles are updated with proper timestamps; they just aren't uploaded to the remote server.
I'll try 3.8 and then report back.
Re: RSE won't let me edit remote files any more [message #896396 is a reply to message #896371] Wed, 18 July 2012 05:33 Go to previous messageGo to next message
I found something. If I create the connection on SSH only with SFTP everything syncronizes ok. But I cannot use SSH only because it screws up the file encoding on my remote server (it's Unix for mainframe, and if I change the encoding to UTF-8, it still does not work for Eclipse editor). But SCP now prevents from updating the remote files.
The results for Indigo are the same.
Re: RSE won't let me edit remote files any more [message #896416 is a reply to message #896396] Wed, 18 July 2012 06:41 Go to previous message
Sorry for disturbing; I've made it work. On the other days I needed to change Windows settings for default application language and format standards for some specific software. I've changed that back to the USA ones, re-created my connections (SSH with SCP) and it worked. The message disappeared from the log.
Thanks anyway Smile
[Updated on: Wed, 18 July 2012 06:41]
Report message to a moderator
Previous Topic:[Announce] TM 3.4 has been released with Juno
Next Topic:RSE vs. CNF?
Current Time: Sat May 18 05:19:36 EDT 2013
Powered by FUDForum. Page generated in 0.01721 seconds
