Home » Eclipse Projects » Eclipse 4 » start application window from osgi console
start application window from osgi console [message #895391] Thu, 12 July 2012 12:47 Go to next message
Jan Pfeil is currently offline Jan Pfeil
I want to start my e4 application from the osgi console by command. Is that possible?
My simple e4 application runs well so far. It uses e4 application model and declarative services.
My product based launch configuration uses VM arguments -Dosgi.noShutdown=true and Program arguments -consoleLog -console.
When I close the main window I can run commands from the console.
I'd like to restart the application window from the console now.
I tried the apps and startApp commands to no success and I don't even know if this is a useful approach.
When the application window is present I get:
osgi>apps
org.eclipse.e4.ui.workbench.swt.E4Application [running] [not launchable]
when the application window is closed I get:
osgi>apps
org.eclipse.e4.ui.workbench.swt.E4Application [launchable]
startApp gives me
osgi> startApp org.eclipse.e4.ui.workbench.swt.E4Application
Launched application instance: org.eclipse.e4.ui.workbench.swt.E4Application.1
but no application window opens.
Any ideas?
Jan
[Updated on: Mon, 16 July 2012 11:58]
Report message to a moderator
Re: start application window from osgi console [message #895895 is a reply to message #895391] Mon, 16 July 2012 09:00 Go to previous messageGo to next message
Joseph Carroll is currently offline Joseph Carroll
Jan-
What are you trying to accomplish by starting the eclipse application from the console?
I am certainly not an osgi expert, but I will see what I can come up with.
JD
Re: start application window from osgi console [message #895955 is a reply to message #895895] Mon, 16 July 2012 11:57 Go to previous messageGo to next message
@JD
My intention is to have a backend constantly running. The backend is processing data feeds.
I want to run some kind of admin user interface (e4) provided by a bundle in that osgi container. That UI would run on demand by starting the bundle.
The only alternative I see is to run the UI in a separate container and establish a communication stack between the two.
Jan
Re: start application window from osgi console [message #896301 is a reply to message #895955] Tue, 17 July 2012 19:09 Go to previous message
Jan-
I checked around a little and it seems to be possible to run a dynamic GUI application from the console. Some one pointed me towards the Equinox wiki [1] which has several great examples. However, I do not believe it is possible to run an Eclipse4 application from the console due to completing resources.
If I come up with anything more over the next several days I'll post it here, so make sure you have post notification selected.
Take care,
JD
[1] http://wiki.eclipse.org/Equinox_Application_Model_Demo#Running_using_the_application_selector_GUI
Previous Topic:'simple' has been deprecated: renamed as swt-simple
Next Topic:CSS & DI
Current Time: Tue May 21 08:18:44 EDT 2013
Powered by FUDForum. Page generated in 0.08041 seconds
