Home » Eclipse Projects » Mylyn Intent » Are there plans on supporting ';' inside Strings ?
Are there plans on supporting ';' inside Strings ? [message #895998] Mon, 16 July 2012 15:42 Go to next message
Torsten  is currently offline Torsten
Hi Guys, I love your tool.
Just came around it and startet programming a tutorial
style-introduction to mdsd. Somehow the editor/parser did not accept a
semicolon inside a String literal which would be very useful to
integrate simple source-code in ecore-models.
Did I miss a point?
@M
warteschlange {
eClassifiers += new EClass NamedElement {
abstract = "true";
eStructuralFeatures += new EAttribute name {
eType = String;
eOperations += new EOperation toPresentation {
eType = String;
eAnnotations += new EAnnotation {
source = "http://www.eclipse.org/emf/2002/GenModel";
details += new EStringToStringMapEntry {
key = "body";
value = "return name;";
M@
The trouble lies in the last line: value="... ;" which raises
"Unrecognized structural feature" annotation
Torsten.K
Dipl.-Ing. Torsten Krämer
Fachgebiet Bauinformatik
Technische Universität Berlin
Sekr. TIB1-B8
Gustav-Meyer-Allee 25, 13355 Berlin
Büro : Gebäude 13b - Zimmer 504
Tel. : +49 (0) 30 314 72303
Fax : +49 (0) 30 314 72301
Email: Torsten.Kraemer@xxxxxxxx
WWW : http://www.bauinformatik.tu-berlin.de
Re: Are there plans on supporting ';' inside Strings ? [message #896076 is a reply to message #895998] Tue, 17 July 2012 03:57 Go to previous messageGo to next message
Alex Lagarde is currently offline Alex Lagarde
Hi Torsten,
first of all, thanks a lot for your positive feedback!
We will check this bug ASAP (this week hopefully), could you raise a bugzilla issue with your use case in attachement ? Here is the link to post the issue (in the "Mylyn > Mylyn Docs Intent" category and the "Intent Core" component) https://bugs.eclipse.org/bugs/enter_bug.cgi .
Did you know that in addition of models, Intent can also synchronize any technical artifact (Java Code, C++ code, samples on the internet...) as long as you have plugged the corresponding synchronization bridge? More details here http://www.eclipse.org/intent/pages/transcripts/2012_AgileALMConnect/img17.html
William and I are working very hard to make the next Intent release (0.7 SR1) as stable as possible, with new facilities for automatically fixing synchronization issues.
If you want to have a preview of this release, you can download the latest Intent version on hudson (https://hudson.eclipse.org/hudson/job/mylyn-docs-intent-0.7-nightly/ under features/org.eclipse.mylyn.docs.intent.update/target) and install the zip (direct link : https://hudson.eclipse.org/hudson/job/mylyn-docs-intent-0.7-nightly/lastSuccessfulBuild/artifact/features/org.eclipse.mylyn.docs.intent.update/target/org.eclipse.mylyn.docs.intent.update.zip) in your running Eclipse.
Best Regards,
Alex
[Updated on: Tue, 17 July 2012 03:58]
Report message to a moderator
Re: Are there plans on supporting ';' inside Strings ? [message #896181 is a reply to message #896076] Tue, 17 July 2012 10:00 Go to previous messageGo to next message
William Piers is currently offline William Piers
I just fixed the bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=385298
The correction will be integrated in 0.7SR1.
Meanwhile you can use the latest nightly build which integrates the fix:
https://hudson.eclipse.org/hudson/job/mylyn-docs-intent-0.7-nightly/360/artifact/features/org.eclipse.mylyn.docs.intent.update/target/org.eclipse.mylyn.docs.intent.update.zip
(this is an archived update site)
Best Regards,
William
Re: Are there plans on supporting ';' inside Strings ? [message #896232 is a reply to message #896181] Tue, 17 July 2012 12:22 Go to previous message
It works !
Thanks for the quick fix- I didn't even find the time to give a proper
bugzilla entry :-)
Torsten
Am 17.07.2012 16:00, schrieb William Piers:
> Hello,
> Best Regards,
> William
Sekr. TIB1-B8
Previous Topic:Cannot install Intent
Next Topic:Trying retro documentation ....
Current Time: Sun May 19 12:52:19 EDT 2013
Powered by FUDForum. Page generated in 0.01686 seconds
