Home » Eclipse Projects » Eclipse Platform » shared install: private plug-ins not showing up
shared install: private plug-ins not showing up [message #893880] Thu, 05 July 2012 15:19 Go to next message
Carsten Reckord is currently offline Carsten Reckord
Hi there,
I'm trying to set up a shared install where the shared instance is a fully
initialized eclipse and the local instance is supposed to have additional
plug-ins installed on top.
In this case, the shared instance is my normal development eclipse, which I
have full write-access to. To do this, I am starting with:
<shared>/eclipse.exe -vmargs \
-Dosgi.configuration.cascaded=true \
-Dosgi.configuration.area=<local>/configuration \
-Dosgi.sharedConfiguration.area=<shared>/configuration \
-Dosgi.sharedConfiguration.area.readOnly=true \
-Dosgi.install.area.readOnly=true
This seems to be working fine. The workspace comes up and all plug-ins from
the shared install are working properly. When I install stuff, it gets
installed into <local>/plugins and features. <local>/p2 and
<local>/configuration/org.eclipse.equinox.simpleconfigurator/bundles.info
get updated successfully, too.
However, after installing plug-ins into the local instance and restarting,
the new features are not available. I see them listed in Installation
Details -> Installed Software, but not in the Plug-Ins or Features lists or
the Plug-In Registry view (the Plug-Ins view does show them, though).
Any ideas?
Carsten
Re: shared install: private plug-ins not showing up [message #895899 is a reply to message #893880] Mon, 16 July 2012 09:10 Go to previous messageGo to next message
Anybody? Or might the P2 group be a better place for this question?
On 05.07.2012 21:19, Carsten Reckord wrote:
> Hi there,
> Any ideas?
> Best regards,
> Carsten
Re: shared install: private plug-ins not showing up [message #895907 is a reply to message #895899] Mon, 16 July 2012 09:19 Go to previous messageGo to next message
Paul Webster is currently offline Paul Webster
Yes, I think your question is good for the p2 forum.
Do you have to set your shared installed to "cascade" or is that something that should be done when running as your second user.
Also, I thought it was possible to install eclipse and add some plugins (writable) and then switch to another user that can see the install as read-only and just fire up the eclipse. By default it creates a $HOME/.eclipse/<some_directory>/ and puts configuration, p2, plugins and features in there. But I'm not 100% sure I'm not remembering it incorrectly.
This is the only page I know of that has details on multi-user installs: http://help.eclipse.org/juno/index.jsp?topic=%2Forg.eclipse.platform.doc.isv%2Freference%2Fmisc%2Fmulti_user_installs.html&cp=2_1_3_7
Later,
PW
Re: shared install: private plug-ins not showing up [message #895992 is a reply to message #895907] Mon, 16 July 2012 15:06 Go to previous message
Thanks. I'll take it there. I wasn't quite sure where p2 ends and platform
begins, so I started here.
Oh, my bad, I did phrase that part rather badly. The command line from my
previous post was what I execute as my "second user" to force Eclipse to use
the shared location as read-only, which it isn't file system-wise (because
actually it's both the same user, just with a "basic" and "extended" setup)
That was actually my starting point :) Based on scenario 3, I tried
achieving the same without having to make the shared location read-only.
Carsten
Previous Topic:Implementing folder/files as derived
Next Topic:how to extend main menu bar action of eclipse
Current Time: Mon May 20 08:00:59 EDT 2013
Powered by FUDForum. Page generated in 0.01827 seconds
