Home » Eclipse Projects » EGL Development Tools » What happened to IRest?
What happened to IRest? [message #895672] Sat, 14 July 2012 11:32 Go to next message
Richard Moulton is currently offline Richard Moulton
Member
At some point support for IRest has been removed from EDT; I think this may may have been removed from 0.81M3.
I used to be able to do the following ...
package client;
import org.eclipse.edt.rui.widgets.Div;
import org.eclipse.edt.rui.widgets.HTML;
handler test type RUIhandler{initialUI =[ui], onConstructionFunction = start, cssFile = "css/testirest.css", title = ""}
    ui div{children =[result]};
result html{};
    function start()
		myIRest IRest?;
		uri string = "http://www.eclipse.org/";
		call myIRest.invokeGet(uri)
			returning to gotpage
			onException serviceExceptionHandler;
    end
    function gotpage(retResult string in)
    	result.text = retresult;
    end
    function serviceExceptionHandler(exp AnyException in)
		s String = "An exception has occurred: " + exp.message + " <br>";
		if(exp isa ServiceInvocationException)
			s += "Detail1: " + (exp as serviceInvocationException).detail1  + " <br>";
			s += "Detail2: " + (exp as serviceInvocationException).detail2  + " <br>";
			s += "Detail3: " + (exp as serviceInvocationException).detail3  + " <br>";
		end
		SysLib.writeStdout(s);
	end
end
I see that there have been changes to the service access within 0.81M3 and I've followed the link to http://wiki.eclipse.org/EDT:Resource_Binding_Services but I can't get the syntax right to perform the same function.
How would I now perform the http get?
Richard
Re: What happened to IRest? [message #895943 is a reply to message #895672] Mon, 16 July 2012 11:28 Go to previous messageGo to next message
Joseph Vincens is currently offline Joseph Vincens
Member
Hi Richard,
To do a function invocation: create a proxy function that represents the service end point.
In this case the end point is a REST service, accessed using an HTTP GET with a URL of http://www.eclipse.org/.
    library ServiceInvocationLib
	function invokeGetEclipse(){
		@Resource {uri="binding:httpEclipse"}, //the egldd entry named httpEclipse defines the URL.
		@REST{  //indicates a REST service endpoint
			method = HttpMethod._GET  //indicates that a http get is used to access the data
	end
    end
Create a new egldd Rest binding named httpEclipse with a baseURI = http://www.eclipse.org/
Here how you would use the proxy function to invoke the service.
    function start1()
		call ServiceInvocationLib.invokeGetEclipse()
    end
regards,
Joe
[Updated on: Mon, 16 July 2012 11:29]
Report message to a moderator
Re: What happened to IRest? [message #895961 is a reply to message #895943] Mon, 16 July 2012 12:27 Go to previous messageGo to next message
Gregory Testa is currently offline Gregory Testa
When I try this syntax, I am getting an error, "The returning to or onException function gotpage requires 0 parameter(s)."
Re: What happened to IRest? [message #895973 is a reply to message #895961] Mon, 16 July 2012 13:36 Go to previous messageGo to next message
Dan Darnell is currently offline Dan Darnell
Use this proxy function instead:
function invokeGetEclipse() returns (string){
		@REST{
end
Notice that it returns a string ... probably the result you are looking for.
--Dan
[Updated on: Mon, 16 July 2012 13:41]
Re: What happened to IRest? [message #895978 is a reply to message #895973] Mon, 16 July 2012 14:01 Go to previous messageGo to next message
Just what I needed. Thanks, Dan!
Re: What happened to IRest? [message #896566 is a reply to message #895978] Wed, 18 July 2012 19:08 Go to previous message
Member
Joe/Dan,
Many thanks that's working well.
I made a couple of slight tweaks. I'm building the uri on the fly and I couldn't see a way of doing that through a binding entry, so I ended up with the following library part ...
package client.libraries;
	function invokeGet() returns(string)
	end
end
... and the following code in my handler ...
		// Retrieve summary data page for given sector csi
		myBindingVariable IHttp? = new HttpRest{
			request.uri = getSummaryURI + strLib.clip(sectorCSI)
		call ServiceInvocationLib.invokeGet()
			using myBindingVariable
			returning to gotSectorSummary
Richard
Previous Topic:Form field parsing issue
Next Topic:MySQL table access
Current Time: Sat May 18 23:15:04 EDT 2013
Powered by FUDForum. Page generated in 0.01815 seconds
