Home » Eclipse Projects » BIRT » Only one column in crosstab
Only one column in crosstab [message #895642] Fri, 13 July 2012 20:10 Go to next message
payen bertrand is currently offline payen bertrand
I'm facing strange problem with a crosstab under BIRT 3.7.
On my PC (Windows XP) : Under Eclipse/Birt my crosstab is working fine : all rows and columns are OK.
But on my server (Linux) : when I'm running the report with Birt Viewer only the first column is shown....(and rows seems OK).
To be sure that it's not my data that are KO I'm using the same MySql base.
No error message...
Have you an idea about this problem ?
Maybe just a clue ...
It must be a stupid stuff, as nobody seems have faced it before...
Help :{
NB : I'have just looked at HTML...all data are in the HTML. The problem must be linked to CSS or to another displaying stuff
[Updated on: Fri, 13 July 2012 20:29]
Report message to a moderator
Re: Only one column in crosstab [message #895645 is a reply to message #895642] Fri, 13 July 2012 21:10 Go to previous messageGo to next message
I tried to change raport "layout" parameter from Fixed to Auto... and columns are now displayed.
Is it a bug ?
Re: Only one column in crosstab [message #896035 is a reply to message #895645] Mon, 16 July 2012 22:43 Go to previous message
Jason Weathersby is currently offline Jason Weathersby
Can you post the report? Are there a lot of columns? You could try
switching it back to fixed and then expand the size of the master page.
Jason
> columns are now displayed. Is it a bug ?
Jason Weathersby
BIRT Exchange
Previous Topic:Stored Procedure
Next Topic:Example for drill down feature
Current Time: Thu May 23 12:48:36 EDT 2013
Powered by FUDForum. Page generated in 0.01526 seconds
