Home » Modeling » M2T (model-to-text transformation) » xpand and aspects
xpand and aspects [message #895523] Fri, 13 July 2012 07:26 Go to next message
Matthias N is currently offline Matthias N
Member
as much I know aspect oriented programming is supported by xpand.
I have a GMF project, and when I customize templates, I put them into a folder "templates/aspects/".
The aspects however must follow the same directory structure as the original template, e.g.
the original template:
org.eclipse.gmf.codegen/templates/xpt/editor/Editor.xpt
the aspect:
<my project>/templates/aspects/xpt/editor/Editor.xpt
Therefore, I can only change the Editor.xpt template. So, if my changes concern several templates, I have to create an aspect template for each of those.
What I want to have is an aspect, e.g. color.xpt which contains all template changes within this one file. Example:
color.xpt
<<Around template/xx/yy/ ...>>
<<EndAround>>
<<Around template/zz/aa// ...>>
<<EndAround>>
Is this possible ?
[Updated on: Fri, 13 July 2012 07:26]
Report message to a moderator
Re: xpand and aspects [message #895596 is a reply to message #895523] Fri, 13 July 2012 13:32 Go to previous message
Christian Dietrich is currently offline Christian Dietrich
maybe you should ask this in the GMF newsgroup since afaik GMF Xpand is
a Fork to M2T Xpand
~Christian
On 2012-07-13 11:26:04 +0000, Matthias N said:
> the aspect:
> of those.
> color.xpt<<Around template/xx/yy/ ...>>
> <<EndAround>>
> <<EndAround>>
> Is this possible ?
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Previous Topic:[Acceleo] problems with static UML profile
Next Topic:[Acceleo] Collection whose elements are all different
Current Time: Mon May 20 03:25:16 EDT 2013
Powered by FUDForum. Page generated in 0.01567 seconds
