| start application window from osgi console [message #895391] |
Thu, 12 July 2012 12:47  |
Jan Pfeil Messages: 2 Registered: July 2012 |
Junior Member |
I want to start my e4 application from the osgi console by command. Is that possible?
My simple e4 application runs well so far. It uses e4 application model and declarative services.
My product based launch configuration uses VM arguments -Dosgi.noShutdown=true and Program arguments -consoleLog -console.
When I close the main window I can run commands from the console.
I'd like to restart the application window from the console now.
I tried the apps and startApp commands to no success and I don't even know if this is a useful approach.
When the application window is present I get:
osgi>apps
org.eclipse.e4.ui.workbench.swt.E4Application [running] [not launchable]
when the application window is closed I get:
osgi>apps
org.eclipse.e4.ui.workbench.swt.E4Application [launchable]
startApp gives me
osgi> startApp org.eclipse.e4.ui.workbench.swt.E4Application
Launched application instance: org.eclipse.e4.ui.workbench.swt.E4Application.1
but no application window opens.
Any ideas?
Jan
[Updated on: Mon, 16 July 2012 11:58] Report message to a moderator
| Re: start application window from osgi console [message #895955 is a reply to message #895895] |
Mon, 16 July 2012 11:57   |
Junior Member |
@JD
My intention is to have a backend constantly running. The backend is processing data feeds.
I want to run some kind of admin user interface (e4) provided by a bundle in that osgi container. That UI would run on demand by starting the bundle.
The only alternative I see is to run the UI in a separate container and establish a communication stack between the two.
Jan
FUDForum. Page generated in 0.02496 seconds
