Home » Eclipse Projects » Web Tools Project (WTP) » Can jsdt work well with jsp in eclipse 3.5.2?
Can jsdt work well with jsp in eclipse 3.5.2? [message #895230] Thu, 12 July 2012 04:15 Go to next message
liu guihai is currently offline liu guihai
I am using eclipse 3.5.2 with wtp plugins.However,I find it impossible to trigger js assist in a jsp file whether the project is a js project or a web project.Is this function not supported in e3.5.2?
Re: Can jsdt work well with jsp in eclipse 3.5.2? [message #895321 is a reply to message #895230] Thu, 12 July 2012 08:53 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
It should be supported, but you should update your installation to Juno or 3.8. There's no further maintenance planned to be done for 3.5.2.
Nitin Dahyabhai
Eclipse WTP, IBM
Re: Can jsdt work well with jsp in eclipse 3.5.2? [message #895359 is a reply to message #895321] Thu, 12 July 2012 10:54 Go to previous message
Thanks a lot for your answer.I am interested in the jsdt and studying its source,facing tons of code.Is there any good proposal to learn the jsdt? Thanks a lot again for your next response to this question.
Previous Topic:how to fix "Attribute value refers to missing resource"/"Resource not found"?
Next Topic:JSDT "Open Declaration" NOT WORKING for JsDoc "hints". OK if type is inferred. A
Current Time: Sun May 19 17:59:04 EDT 2013
Powered by FUDForum. Page generated in 0.01614 seconds
