| fail to make table [message #895200] |
Wed, 11 July 2012 22:59  |
Jorge Ryan Messages: 5 Registered: June 2012 |
Junior Member |
hello,
I just made a small webpages that enter data into database.
I have specified that in persistence.xml to drop-create-tables. however, if there is no table, it will generate exception.
if I coded create-tables, ALSO no table in database, it would be fine. Everything runs smooth. is it a known issue?
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.SQLSyntaxErrorException: ORA-00942: table or view does not exist
Error Code: 942
Call: INSERT INTO BOOK (ID, DESCRIPTION, ILLUSTRATIONS, ISBN, NBOFPAGE, PRICE, TITLE) VALUES (?, ?, ?, ?, ?, ?, ?)
bind => [7 parameters bound]
Query: InsertObjectQuery(com.apress.javaee6.chapter10.Book@11a48bb4)
| Re: fail to make table [message #895403 is a reply to message #895200] |
Thu, 12 July 2012 13:25  |
Chris Delahunt Messages: 863 Registered: July 2009 |
Looks like you have set "drop-create-tables" when it should be "drop-and-create-tables" - incorrect values are ignored. Please feel free to file an enhancement to have validation added for the "eclipselink.ddl-generation" property and vote for it.
Best Regards,
Chris
FUDForum. Page generated in 0.02043 seconds
