Home » Eclipse Projects » BIRT » Addition of two number fields Example(Java script through expression builder)(I need one complete script for adding two fields Under Expression Builder)
Addition of two number fields Example(Java script through expression builder) [message #892811] Fri, 29 June 2012 15:50 Go to next message
avinash Kumar is currently offline avinash Kumar
I am new to BIRT. I have XML Data Set. All fields which is defined in this XML is bydefault of Object type. Whenever i am performing simple addition of two fields for example row["a"]+row["b"], its giving some error like Nan.
I just need a simple example where I can add two fields with complete Javascript code so that same concept i can use henceforth.
Your help will be greatly appreciated. I am in urgent need as we have just started similar project.
Thanks!!!
[Updated on: Sun, 01 July 2012 05:37]
Report message to a moderator
Re: Addition of two fields Example(Java script through expression builder) [message #893147 is a reply to message #892811] Mon, 02 July 2012 17:52 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Are you wanting to add to objects? Can you post a snippet of the xml?
Jason
> error like Nan. I just need a simple example where I can add two fields
> Thanks!!!
Jason Weathersby
BIRT Exchange
Re: Addition of two fields Example(Java script through expression builder) [message #894179 is a reply to message #893147] Sat, 07 July 2012 08:08 Go to previous messageGo to next message
Hi Jason,
Thanks for your reply!
Actually, I need to add two fields (object type)
currency 1=euro 75
crrency 2= euro 60
when i am adding these, it saying Nan because both object has text character as some part of it(euro).
could you give me code (java script) as how i can handle this situation?
Thanks once again in advance!!
Re: Addition of two fields Example(Java script through expression builder) [message #895104 is a reply to message #894179] Wed, 11 July 2012 13:04 Go to previous message
What is the real Java data type for the object? Is it just a string?
Jason
On 7/7/12 8:08 AM, avinash Kumar wrote:
> Hi Jason,
> currency 1=euro 75
> crrency 2= euro 60
Jason Weathersby
BIRT Exchange
Previous Topic:Generate excel reports
Next Topic:Duplicate call to Store Procedure
Current Time: Sat May 18 22:08:18 EDT 2013
Powered by FUDForum. Page generated in 0.01555 seconds
