Home » Eclipse Projects » BIRT » Birt rcp report designer 4.2.0 does not lauch
icon8.gif  Birt rcp report designer 4.2.0 does not lauch [message #895039] Wed, 11 July 2012 09:39 Go to next message
Jarod Delaware is currently offline Jarod Delaware
Hey there,
I would like to know if someone could help me to resolve my installation problem with the new version of Birt RCP report Designer 4.2.0. I unzipped the archive and when I click on Birt.exe I have this error message :
An error has occurred, see log file. Do you know how to solve this problem ?
Jarod.
!SESSION 2012-07-11 15:36:55.232 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_33
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2012-07-11 15:36:56.279
!MESSAGE Application error
!STACK 1
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.<init>(ModelServiceImpl.java:92)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:442)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:182)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:554)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.birt.report.designer.ui.rcp.DesignerApplication.run(DesignerApplication.java:38)
at org.eclipse.equinox.internal.app.EclipseAppContainer.callMethodWithException(EclipseAppContainer.java:587)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:198)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Re: Birt rcp report designer 4.2.0 does not lauch [message #895158 is a reply to message #895039] Wed, 11 July 2012 16:27 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Do you get the same error when using the allinone build?
Jason
On 7/11/12 9:39 AM, Jarod Delaware wrote:
> Hey there,
> message :
> problem ?
> Jarod.
> !STACK 1
> java.lang.NullPointerException
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> at
> at
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
Jason Weathersby
BIRT Exchange
Re: Birt rcp report designer 4.2.0 does not lauch [message #895247 is a reply to message #895158] Thu, 12 July 2012 05:14 Go to previous messageGo to next message
Hi Jason,
Thanks for your reply. I didn't download the allinone build. I used to download the RCP designer and it works without any additional download previously. Got this error only with this new version 4.2.0.
I will try to install the allinone build to see.
Jarod.
Re: Birt rcp report designer 4.2.0 does not lauch [message #895341 is a reply to message #895247] Thu, 12 July 2012 10:01 Go to previous messageGo to next message
Brian McMahon is currently offline Brian McMahon
I am having the same problem launching the RCP designer 4.2.0. RCP designer 3.7.2 works fine. Will give the all in one a try.
icon8.gif  Re: Birt rcp report designer 4.2.0 does not lauch [message #895447 is a reply to message #895039] Thu, 12 July 2012 21:17 Go to previous messageGo to next message
Ines Feijao is currently offline Ines Feijao
I have the exact same problem.. Doesn't launch. Please help!
Re: Birt rcp report designer 4.2.0 does not lauch [message #896039 is a reply to message #895447] Mon, 16 July 2012 22:54 Go to previous messageGo to next message
We are looking into this now.
Jason
Jason Weathersby
BIRT Exchange
Re: Birt rcp report designer 4.2.0 does not lauch [message #896043 is a reply to message #896039] Mon, 16 July 2012 23:12 Go to previous message
Patch is available in this bugzilla entry:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=383756
Jason
> Jason
Jason Weathersby
BIRT Exchange
Previous Topic:Support for Multiple Excel worksheets
Next Topic:Birt report export to excel error
Current Time: Fri May 24 03:21:57 EDT 2013
Powered by FUDForum. Page generated in 0.05215 seconds
