Home » Eclipse Projects » Buckminster » Eclipse-SourceReferences (take two)
Eclipse-SourceReferences (take two) [message #894734] Tue, 10 July 2012 09:57 Go to next message
Eike Stepper is currently offline Eike StepperFriend
I repost my question from 2012-05-23 because the team has not replied, yet ;-(
The other day I configured the generation of Eclipse-SourceReferences headers with Buckminster.
The current SimRel report (http://build.eclipse.org/juno/simrel/reporeports/reports/esdata.txt ) shows:
scm:git:git://git.eclipse.org/gitroot/cdo/cdo.git
scm:git:git://git.eclipse.org/gitroot/equinox/rt.equinox.bundles.git;path="bundles/org.eclipse.equinox.app";tag=v20111010-1614
The first is generated by Buckminster. I wonder if the path attribute could/should be generated, too?
Cheers
/Eike
http://www.esc-net.de
Re: Eclipse-SourceReferences (take two) [message #896324 is a reply to message #894734] Wed, 18 July 2012 04:53 Go to previous messageGo to next message
Hi Thomas,
Now I'm asking you directly because I see that you find time to answer other questions here.
Is my question so silly that it's not even worth to tell me that or why am I being ignored on this list?
Cheers
/Eike
Am 10.07.2012 11:57, schrieb Eike Stepper:
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: Eclipse-SourceReferences (take two) [message #896362 is a reply to message #896324] Wed, 18 July 2012 07:57 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Eike,
I'm sorry if you're feeling ignored. Believe me, that's not my (nor anyone else's) intention. In order to answer your
question, some of us would need to do some investigation on the topic. Nobody has had any time to do that yet.
Perhaps if you did some investigation of your own around the Eclipse-SourceReferences and came up with an answer? Then,
if Buckminster isn't doing the right thing, you could enter a bugzilla where you tell us what it ought to do. That would
be really helpful.
- thomas
On 07/18/2012 06:53 AM, Eike Stepper wrote:
> Hi Thomas,
> Cheers
> /Eike
>> Cheers
>> /Eike
Re: Eclipse-SourceReferences (take two) [message #896379 is a reply to message #896362] Wed, 18 July 2012 08:39 Go to previous message
Am 18.07.2012 09:57, schrieb Thomas Hallgren:
> Hi Eike,
Already forgotten ;-)
> In order to answer your question, some of us would need to do some investigation on the topic. Nobody has had any time
> to do that yet.
Ok, it's not a blocker.
Unfortunately not. As I said, I'm not even sure EGit can handle these SourceReferences already.
> Then, if Buckminster isn't doing the right thing, you could enter a bugzilla where you tell us what it ought to do.
> That would be really helpful.
I'm rather sure that some important information is missing from the URLs Bucky has generated. I hope that I eventually
find some time to try EGit again with a proper URL...
Cheers
/Eike
> - thomas
>> Hi Thomas,
>> Cheers
>> /Eike
>>> Hi,
>>> Cheers
>>> /Eike
Previous Topic:Running build in IDE org.eclipse.core.runtime.CoreException is thrown
Next Topic:Adding source features to category.xml
Current Time: Sat Jul 22 08:56:52 GMT 2017
Powered by FUDForum. Page generated in 0.02176 seconds
