| Change path delimiter (from "\" to "/") in resolved relative paths [message #894727] |
Tue, 10 July 2012 05:37 |
Boris Blajevici Messages: 1 Registered: July 2012 |
Junior Member |
Hi everybody
I'm working on a tcl proj with the dltk plugin in eclipse juno.
I've set a folder from the file system (c:\projX\files\) as linked ressource in my eclipse project. All files are contained in this folder.
In the tcl code I adress a certain file from this folder:
e.g.
source test.txt
But when I run the script I get an error: Couldn't read file test.txt - file or folder not found
If I point to this line with the mouse in the editor the tooltip shows "C:\projX\files\test.txt" - which is ok, it seems the relative path works and is resolved correctly
Next thing, I tried to hard code the path:
source C:\projX\files\test.txt
...but I still get the same error!!!
The same error also with
source C:\\projX\\files\\test.txt
After many tries I found out that the tcl interpreter only "understands" paths with forward slash as delimiter. If I hard code the path with forward slash "/" the file is found and read:
source C:/projX/files/test.txt
So it seems that eclipse resolves the relative path and uses backslash as delimiter which cannot be read as a valid path by the tcl interpreter.
Is there a setting in eclipse/dltk/tcl to switch the path delimiter from "\" to "/" when resolving relative paths?
Many thanks in advance.
Boris
FUDForum. Page generated in 0.02289 seconds
