| Integrating jar into RunAs Eclipse Application [message #894066] |
Fri, 06 July 2012 10:22  |
Jens-Uwe Moeller Messages: 12 Registered: February 2012 Location: Hamburg |
Junior Member |
I wrote a grammer and use the JvmDomainModelInferrer. Within this xtend-Code I need to use java-classes a) from different projects in my eclipse and b) from jars, that I integrated into the - lets say domainmodel-project in an own lib directory. In the development-Eclipse I added these jars to the build path. This works fine for the development phase. But when I call RunAs -> Eclipse Application on my domainmodel-project, I get an Eclipse-Instance that does not know about the jars or projects.
The model-generator complains "XText Validation and XText Reconciler Job":
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-07-06 16:09:15.312
!MESSAGE Unable to create class 'org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor' from bundle '252'
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError
My question: What are all the places, where I have to integrate classes, projects, jars, so that they are itegrated into the RunAs -> Eclipse Application?
I tried different solutions, but did not get it to work.
Thanks in advance, Jens
| Re: Integrating jar into RunAs Eclipse Application [message #894096 is a reply to message #894066] |
Fri, 06 July 2012 11:43   |
Jan Kohnlein Messages: 570 Registered: July 2009 |
Looks like you need to learn about Eclipse Plug-in development in
general. Here are some hints, but I guess you will have to look for
other resources on that very wide topic.
- Eclipse plug-ins are developed as Eclipse Java projects with the
plug-in nature. You can convert an existing Java project to a Plug-in
project by using a context menu action on the project.
- Plug-ins define their dependencies to other plug-ins in the MANIFEST.MF
- If you have common jars, it is likely a plug-in version exists at
Eclipse Orbit
So in short:
- convert all your helper Eclipse projects to plug-in projects
- replace dependency declaration using the project's classpath with
plug-in dependencies
- if they exist, use the plug-in wrappers for your libs from orbit
Am 06.07.12 16:22, schrieb Jens-Uwe Moeller:
> bundle '252'
> !STACK 0
> Application?
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
FUDForum. Page generated in 0.01691 seconds
