Home » Eclipse Projects » GEF » [ZEST] Center view on a selected node(What is the best way to center on a node that was selected (listener))
[ZEST] Center view on a selected node [message #894131] Fri, 06 July 2012 16:29 Go to next message
Fabian Günter is currently offline Fabian Günter
I've got the following problem: when a node is clicked (selected), the whole view/graph/eclipse area should be centered on the node so that you would be able to click through a whole graph from beginning to end. I already tried Graph.setLocation(...) which works but doesn't change the canvas of the whole graph so that I have a graph with a white background which ends somewhere and out of that there's only gray. Node.setLocation(...) seems to do nothing at all.
Is there any possibility of achieving what I want? Do I maybe have to write my own layout?
I've appended my current code, if I left something unclear I'd be glad to provide further information.
Thanks in advance for your help.
Code:
addSelectionListener(new SelectionAdapter() {
            public void widgetSelected(SelectionEvent e) {
                Object object = getSelection().get(0);
                // We can only center on nodes, not connections
                if (object instanceof DecisionModelGraphNode) {
                    DecisionModelGraphNode decisionModelGraphNode = (DecisionModelGraphNode) object;
                    Point point = decisionModelGraphNode.getLocation();
                    Dimension nodeSize = decisionModelGraphNode.getSize();
                    setLocation((getSize().x / 2) - (nodeSize.width / 2) - point.getSWTPoint().x, (getSize().y / 2)
                            - (nodeSize.height / 2) - point.getSWTPoint().y);
                    // TODO: Doesn't work as well -_- (a subsequent call to redraw() or layout()
                    // does nothing)
                    decisionModelGraphNode.setLocation(
Re: [ZEST] Center view on a selected node [message #901813 is a reply to message #894131] Tue, 14 August 2012 12:18 Go to previous message
For anyone that has the same problem: You can't do this in the graph itself, you have to write your own LayoutAlgorithm (or extend an existing one) and pass it to the graph via setLayoutAlgorithm(...).
The algorithm and the code in the graph that worked for me is this (the delta is the x- and y-size by which all nodes have to be moved, that is the distance from the center of the graph area to the node that will be centered):
Graph:
        final MyGraphLayoutAlgorithm myGraphLayoutAlgorithm = new MyGraphLayoutAlgorithm(
                LayoutStyles.NO_LAYOUT_NODE_RESIZING);
        setLayoutAlgorithm(myGraphLayoutAlgorithm, true);
                if (object instanceof MyNode) {
                    MyGraphNode myGraphNode = (MyGraphNode) object;
                    Point point = myGraphNode.getLocation();
                    Dimension nodeSize = myGraphNode.getSize();
                    Point delta = new Point();
                    delta.setX((getSize().x / 2) - (point.x + nodeSize.width / 2));
                    delta.setY((getSize().y / 2) - (point.y + nodeSize.height / 2));
                    myGraphLayoutAlgorithm.setDelta(delta.getSWTPoint());
                    applyLayout();
LayoutAlgorithm:
public class MyGraphLayoutAlgorithm extends SpringLayoutAlgorithm {
     * The delta to relocate the nodes.
    private Point delta;
     * Call super constructor.
     * @param style
     *            The style of the layout.
    public MyGraphLayoutAlgorithm(int style) {
        super(LayoutStyles.NO_LAYOUT_NODE_RESIZING);
    protected void preLayoutAlgorithm(InternalNode[] entitiesToLayout, InternalRelationship[] relationshipsToConsider,
            double x, double y, double width, double height) {
        super.preLayoutAlgorithm(entitiesToLayout, relationshipsToConsider, x, y, width, height);
    protected void applyLayoutInternal(InternalNode[] entitiesToLayout, InternalRelationship[] relationshipsToConsider,
        if (delta == null) {
            // First time only
            super.applyLayoutInternal(entitiesToLayout, relationshipsToConsider, x, y, width, height);
        } else {
            for (InternalNode node : entitiesToLayout) {
                // node.setInternalLocation(point.x, point.y);
                // node.setLocationInLayout(point.x, point.y);
                node.setLocation(node.getInternalX() + delta.x, node.getInternalY() + delta.y);
     * Set the delta.
     * @param delta
     *            The delta to be set.
    public void setDelta(Point delta) {
        this.delta = delta;
[Updated on: Tue, 14 August 2012 12:19]
Report message to a moderator
Previous Topic:[Zest] Adding widgets
Next Topic:new javadoc for Zest2??
Current Time: Sun May 26 00:50:39 EDT 2013
Powered by FUDForum. Page generated in 0.01642 seconds
